05' P0a08-264/P0a09-591 head scratcher
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Michael Cyr, Apr 6, 2022.
  1. Michael Cyr
    Michael Cyr Junior Member
    Belgrade, ME
    Hi all. Hoping for some pointers here because I'm stuck. I have an 05' with red triangle, ABS, Brake lights on, as well as the battery and car warning icons on the MFD. The car runs, the HV battery appears to charge, as well as the 12v battery (13.8v with engine on).
    Techstream shows P0a08 with code 264 and P0a09 with code 591. This seems related to the 12v charging circuit. The 12v battery was replaced before I got the car and it appears that the codes have been present since then. The replacement battery is a NAPA brand sealed AGM.
    I have checked a number of thing and changed the engine compartment converter.
    1. I have battery voltage on the output side of the battery compartment fusible link, both on the skinny white wire and the thick white wire. The 5amp and 100amp fuses test good.
    2. The fusible link in the engine compartment fuse block tests good.
    3. Testing at c5 & c6 harness connectors on the back of the converter shows that I have all expected voltages EXCEPT I have an open on the NODD pin on the harness and do not see the 100ohm to ground reading that is called for.
    4. I changed the converter because I had another one. no effect. I opened up on the original converter and there's no evidence of damage on top or bottom boards.
    5. I've checked the pins and connectors on the HV control ECU behind the passenger side dashboard. Connectors and pins look good.
    Should I be looking to replace the HV control ECU at this point. The manual talks about checking the NODD hardness but I don't know where to test it back to.. presumably some pin on the HC control ECU. I think the check on the C5 for voltage confirms that both 12v connections to the aux. battery are good.
    Any other troubleshooting tips for this?
    Thanks!
    Mike in Maine
    52,386
  3. Michael Cyr
    Belgrade, ME
  4. ChapmanF
    18,538
    The P0A08 code is a general one indicating some abnormal status reported by the DC/DC converter at the front of the car. Pretty much anything that interferes with the converter, causing it to shut down or failsafe, will lead to a discharging 12 volt battery and eventually to a P0A08-264 code. So its workup section in the repair manual has a bunch of things to potentially check.
    The P0A09-591 code is much more specific. It refers to the VLO circuit between the converter and the HV ECU.
    The HV ECU has two single-wire circuits it uses to control and monitor the DC/DC converter. NODD (that violet wire, between C5 pin 4 and H16 pin 24, works bidirectionally: the HV ECU can use it to wake up or shut down the converter, but also to read some converter status back. (The details on how that works are sketchy.)
    The VLO circuit, the blue wire between C5 pin 5 and H16 pin 31, is unidirectional. The HV ECU uses it to tell the converter to lower its output voltage a little, under some circumstances.
    P0A09-591 means that VLO wire is either open or shorted to ground (from the HV ECU's perspective). You can see this is specific even about the kind of fault. If the wire were instead shorted to battery voltage, that would give a different code (P0A10-592).
    So it doesn't seem like something too difficult to pin down with a multimeter and some exploration of that circuit (from the converter connections under the hood to the HV ECU behind the glove box).
    Solving that issue might also solve the more generic P0A08.
    SFO likes this.
  5. Michael Cyr
    Belgrade, ME
    Thanks. That is helpful. That is the direction I was going because I get an open on the NODD at the converter, instead of 100-150ohm to ground. The pin numbers and wire colors are very helpful. Mike
  6. ChapmanF
    18,538
    What do you get for VLO, which is the circuit referred to by your trouble code?
  7. James Analytic
    357
    53
    Michigan
    What ever happened to this situation? Any followup?
  8. TwoPriusInTenn
    250
    66
    Tennessee
    I am having this same issue with my daughter's 2009. Same codes before and after converter / inverter swap. Any assistance/follow-up is appreciated. - Norm
  9. ChapmanF
    18,538
    The P0A09 refers to a simple circuit that should be easy to check with a meter. What did you get?
  10. TwoPriusInTenn
    250
    66
    Tennessee
    Thank you. The car is in Florida. I'm back home Tennessee. Where should this be checked with a meter?
  11. ChapmanF
    18,538
    Post #4 should get you oriented.
  12. TwoPriusInTenn
    250
    66
    Tennessee
    At which ECU?
  13. Brian1954
    Brian1954 Senior Member
    2,402
    962
    South Central PA, USA
    As written in post #4,
    HV ECU is the hybrid vehicle control ECU. It is shown in the wiring diagram included in post #4,
    #13 Brian1954, Sep 8, 2025
  14. James Analytic
    357
    53
    Michigan
    In regards to this P0a08 with code 264 and P0a09 with code 591 situation in a 08 I had, wound up being either the 5A fuse on the positive terminal fuse block needing to be a mini style and not the mini low profile and or the 12V battery was bad. I changed both at the same time pretty much. First replacing the as-found 10A mini with the low profile mini 5A. Didn't help. Replaced with a mini 5A and seemed to work. Though I did the fuse first for like a few days before the 12V battery change since seemed weak voltage and CCA plus I didn't drive much since was a ticking engine though didn't notice the code coming back in that time. I inspected the wiring from the positive terminal up as well and didn't notice anything corroded or burnt looking.
  15. TwoPriusInTenn
    250
    66
    Tennessee
    Thank you.
  16. TwoPriusInTenn
    250
    66
    Tennessee
    Just to make sure I'm clear. The hybrid vehicle control ECU is one of the ECUs just behind the glove compartment?
  17. ChapmanF
    18,538
  18. TwoPriusInTenn
    250
    66
    Tennessee
    Great! Thank you.
  19. TwoPriusInTenn
    250
    66
    Tennessee
    As stated in Post 8, we swapped the Converter/Inverter during my last visit to my daughter's house. Having very little time while I am there, I am trying to think through this before I arrive there. I have ordered an HV ECU. With this car being in Central Florida and susceptible to high humidity, could moister be a factor. If so, is there anything to counteract that? Other than moving the car to a drier climate, of course.
  20. ChapmanF
    18,538
    The inverter is an expensive complicated thing at one end of the questionable circuit(s), and the HV ECU is an expensive complicated thing at the other end of the questionable circuit(s).
    I can't predict from here whether everything will be fine after just replacing the expensive complicated things at both ends. That could happen, or it could also happen that the problem persists until someone troubleshoots the questionable circuit(s) in between.
    TwoPriusInTenn likes this.
