LE / SE tire options (17" rim)
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Sep 6, 2025.
  1. Templeton
    Templeton Active Member
    321
    114
    usa
    2024 Prius Prime
    SE
    I was looking around at replacement tires for our gen5 prime. There are a lot of good tires out there, but very few of them are available in size 195/60R17.
    We do get some snow and ice (not a lot, but some), so l am wondering what folks have found and/or can recommend in good quality, long lasting, low rolling resistance all-weather tires in size 195/60R17 or 205/60R17. And that don't appreciably harm mileage or EV range. Thanks.
  2. KMO
    KMO Senior Member
    2,004
    729
    Finland
    2023 Prius Prime
    215/55R17 is an acceptable size for the original 17x6.5" rims, and a lot more common. I suggest including that size in your search.
    (Can't advise on all-weather - I'm switching between summer 195/50R19 and studded winter 215/55R17).
    james nicol and otatrant like this.
  3. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Thanks, but l don't want to go that wide. Plus, a narrower tire does better in snow and mud too. Anyone know of decent tires in the OE size (for 17" rims)?
  4. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If you wait a bit, CrossClimate 3 in 205/55R17 is a possibility. 1.1% smaller than the stock. You'd only lose about 1/8" of ground clearance. It was just announced in Europe. Should eventually make it to North America.
    For the 19" owners, Michelin Europe has also added a CC3 205/50R19. 1.5% bigger than stock. I think I've found my next tire.
    otatrant likes this.
  5. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Thanks, that is a good tire, but l really want a sidewall equal to stock or, better, slightly taller than stock, like a 205/60R17 (but that size seems even harder to find).
  6. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, I'm not certain anyone out there(in North America at least) makes a 205/60R17. Your realistic choices are between the 205/55R17 and the 215/55R17. You need to decide whether a small reduction in sidewall/clearance or a small reduction in mpg is more important to you.
    205/55R17
    Pros - Should be about the same mpg. Probably very, very slightly better at city speeds and very slightly worse at highway speeds. CC2 available now.
    Cons - Tiny bit smaller tire. Lose about 1/8" ground clearance and about 3/16" sidewall. CC3 not available yet - maybe not until next year.
    215/55R17
    Pros - Very slightly bigger tire. Less than 1/8" more sidewall and negligible increase in clearance. Lots of great tire choices.
    Cons - Small but noticeable hit in mpg due to increased weight and air resistance. Starting to be a little wide for the wheel, but still acceptable.
    215/60R17
    Pros - A full 1/2" more sidewall, and 1/2" more ground clearance over stock.
    Cons - Bigger hit to mpg over 215/55R17. Not many great tires in this size, but some are available. Also a little wide for the wheel(but still acceptable).
    scruffy, Winston Smith and otatrant like this.
  7. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Going to a taller sidewall might be reasonable for me.
    But anything available in the usa that is decent that is in the actual OE size, so 195/60R17 ?
  8. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Nope. Only mediocre(at best) all-season and a great winter. No all-weather.
    All-Season:
    Bridgestone Ecopia EP422 Plus
    Toyo Extensa A/S II B
    Goodyear Assurance MaxLife2
    Winter:
    Michelin X-Ice Snow
  9. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Good info, thanks.
    I got the stock toyo on there now, do you know much about the ecopia or the goodyear?
    Also, l noticed this one also comes in 195/60R17, and it also appears to be an all-weather tire. Is it any good ?
    Nexen Tire › N'Blue 4 Season 2
  10. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sorry, no idea to either question. I suspect there are no major differences between the Toyo, Bridgestone or Goodyear. I think they're all standard quality tires that emphasize efficiency and economy over grip performance.
    As for the Nexen, I had never heard of that brand before. Google says it's a budget South Korean brand that's been around for 70 years(so they were founded shortly after the Korean War). I don't think I'd personally try them, but I probably live in harsher conditions than you do. I'm also a bit of a tire snob. I had several bad experiences due to bad tires when I was in my teens/twenties, so I'm no longer willing to compromise to save a few bucks.
  11. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Thanks for all of the suggestions and input. l too would be more of a tire snob, but not many decent choices for the gen5 SE.
    Totally unrelated, l got myself a Toyota OE spare and jack at very low cost with your forum suggestions, so thanks. The jack is in the car, l keep the donut spare in my shed unless l take a road trip (no easy space in the prime). But, l am curious, is it necessary (or recommended) to get the spare balanced?
  12. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No, you don't need to balance it. A compact spare has low mass, isn't meant to be driven over 50/55mph, or driven more than 50 miles. A full size spare should be balanced like any other tire, but not a compact spare.
    Templeton likes this.
  13. Winston Smith
    Winston Smith Active Member
    388
    261
    OH
    2024 Prius
    LE AWD-e
    True, all other things being equal. If you open the search to other sizes, those things may not be equal though.
    A narrower ultra low rolling resistance tire may do quite a bit worse in snow than a wider all season. There are so many choices in 215/55 that they can be bewildering for someone like me who doesn't make a hobby of tire shopping.
    The Dunlop Enasaves that came on Corolla were pretty good on a dry road and provided measurably better efficiency than the tire with which I replaced them, but were not safe in the wet and snow. I bought new wheels and mounted Michelin Defenders, a good all season tire with good water evacuation. Efficiency dropped a bit but I gained consistently mediocre adhesion in rain and snow.
    Choosing from a size everyone makes may allow you to better pursue your priorities.
    #13 Winston Smith, Sep 7, 2025
    KMO likes this.
  14. bob12345
    bob12345 New Member
    25
    Knoxville, TN
    2024 Prius Prime
    SE
    What about 205/55/17? Only 1.9% difference in circumference than stock.
    Several all season options including non run flats like Michelin Cross Climate 2 and Continental TrueContact Tour 54.
    I do not have experience with any new tires yet for this vehicle, but these two did receive good ratings on Tire Rack.
  15. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Yeah, if I went with a tire size different from OE (which I might end up doing, not sure yet), I would want to go to a slightly taller sidewall vs a shorter sidewall. Lots of killer potholes out here.
  16. bob12345
    bob12345 New Member
    25
    Knoxville, TN
    2024 Prius Prime
    SE
    Sounds like 215 width is what you will need if you want taller sidewalls and a decent tire selection. Hopefully someone can chime in with winter environment experience too. Maybe difficult to find a tire with eco focus if you also prefer a tire that favors winter.
  17. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    I don't have any personal experience, but it looks like michelin makes a winter tire in the OE size (for 17" rims), see one of hammersmith's posts above.
  18. bob12345
    bob12345 New Member
    25
    Knoxville, TN
    2024 Prius Prime
    SE
    Are you planning to have two sets of wheels and tires? The Michelin X-Ice snow are dedicated winter tires.
  19. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Oh no, I am not.
    Sorry, I thought you were looking for good winter tires for a gen5 (with 17" rims).
    I am likely going to do all-seasons or all weathers, well, if I can find some that are good.
  20. james nicol
    james nicol New Member
    Brooklyn New York
    2025 Prius
    LE AWD-e
    useful and practical info 215-55-17 on the stock wheels should be ok if you live in the snowy parts just put a dedicated snow on when the season suggests no all season beats a dedicated snow
    #20 james nicol, Sep 7, 2025
