LE / SE tire options (17" rim)
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Sep 6, 2025.
  1. Hammersmith
    Hammersmith Senior Member
    2,315
    2,354
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The OP said in their first post that they don't get much snow and ice, but they do get some. They specifically asked about all-weather tires, which means they considered dedicated winter tires and decided they didn't need them(which is probably the correct call for their conditions). An all-weather tire would give them the snow/ice performance they need without having to swap between two sets of tires/wheels.
    (just in case you didn't know, all-weather tires are not the same as all-season tires - unless we're comparing North American all-weather to European all-season - those are the same)
    Templeton likes this.
  2. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    Thanks, but to clarify better, l would prefer all weather tires, but good all season tires will likely be OK too (not my preference necessarily, but with these rare gen5 tires, 'beggars can't be choosers').
  3. Mendel Leisk
    41,643
    Maybe it's a wash, when you consider Toyota recommends a 6 monthly tire rotation? If you DIY changes and have the storage space, rotating one set of tires is not much different than doing the rotations in conjunction with changing between all-season and snows. There's also the advantage, that you can wash/wax the wheels coming off, at your leisure.
  4. Winston Smith
    Winston Smith Active Member
    359
    241
    OH
    2024 Prius
    LE AWD-e
    If you are physically able, rotating your own wheels has the advantage that you will know each wheel was correctly torqued with a torque wrench. Any opportunity to keep your brake discs away from an impact wrench seem like a way to keep them from being bent.
  5. Hammersmith
    2,315
    2,354
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    But you also have to factor in how much you drive per year. Say you only drive 15k km a year. And let's say your summer/winter split is 9k/6k. Seven full years of life(via date code on the tire) is really the max you want to use a tire. More realistically, you should start looking for a replacement during the sixth year of life and do the actual replacement late in the sixth year or early in the seventh.
    So that means roughly 55k km on the summer tires and 35k km on the winter tires. Most good all-season tires are rated for 90k or more(some much more), and good winter tires should give you 65k. So you'd be leaving 40% or more of your tread unused when you do the replacement. That's a big waste of money.
    On the flip side, if you can get by the whole year with an all-weather, then all of that 15k km a year goes on a single set of tires. A good all-weather tire should get 100k km or more. So at 15k per year, that would mean you would start running low on tread just as you were approaching the 6-7 year mark.
    My rule is 20k km or less yearly driving, all-weather no question*. 40k or more, dedicated winter tires no question. Anything in between is a judgement call depending on where you are in that spectrum, what tires are available in your size, and exactly what types of winters you get. I'm right at 20k, but I'm doing winter tires solely because there's no (quality)all-weather in my size and my winters can get rough. I'm a prime candidate for all-weathers as soon as the CC3 gets to North America in 205/50-19(confirmed it's coming) or 195/50-19(still waiting).
    *unless you have crazy winters, like you live in the mountains or something
  6. Mendel Leisk
    41,643
    Oh cripes, we're doing about 3k kms yearly, and have all-season and snow tire sets. It used to be more, lol. Anyway, here we are, lol.
    I do agree with your logic. Doubly so considering snow is only sporadic here, and we're rarely if ever obligated to drive.
    That's assuming you're infallible. I have snugged them, lowered the car, and forgotten to do final tightening with torque wrench. It was son's car, I realized an hour or two later, immediately called him, he got out the car's lug wrench and gave them all a good torque, sans torque wrench. No wheels fell off...
    My trick now, as soon as I've snugged the nuts (in the air), is to put the socket on the torque wrench, and lay it on the ground, in a prominent location, where I can't miss it. :)
    #26 Mendel Leisk, Sep 9, 2025
  7. Hammersmith
    2,315
    2,354
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Heck, one time this spring I forgot to fully tighten any of the front tire nuts. Some weren't even hand tight, they were just spun on a few times. I had just installed those front side radar sensors and was focused on testing them. Thankfully I only drove around the block and realized my mistake on the way back. But it was a bit of an "oh, crap" moment when I remembered.
  8. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    After rotating, I also somewhat tighten the nuts in the air, and then fully torque after the wheel is back on the ground.
    But I am curious to what degree should one tighten in the air? For the gen5 final torque is 76 ft-lbs, correct? Should one then tighten the bolts to 60 ft-lbs in the air? 50? 40? 30? finger tight? Or?
  9. Mendel Leisk
    41,643
    When I’m doing wheel swaps I try to keep the underside of tires to an inch clear at most, easier lifting the wheels. Then when preliminarily tightening lug nuts I jam a wheel chock under the side it’s going to rotate, try to push it on with my foot, and bounce the long handled wrench on the lug nuts as best I can. The wheel starts slipping on the chock, I’m done.
    I’d guess I get 20~30 ft/lb at most. Seems like enough to take just the dead-load of wheels on the ground. And then 76 ft/lb once the car is down, in a crisscross. That’s third gen, and likely 4th gen as well. For 5th gen I’d check owners manual, might have changed, it’s a somewhat beefier wheel.
    a little trivia: Tesla model 3 lug nuts are 129 ft/lb. Removing them I find my corded electric impact is near its limit, has to hammer at them a second or more before they break loose.
  10. GeoJ
    GeoJ Active Member
    205
    187
    United States
    2023 Prius Prime
    XSE
    I am not tire knowledgeable, when you say with the CC3 205/50R19 you have found your next tire, can that tire be mounted on the 19" rims, or do you buy new rims? And are there any other adjustments needed to make that tire work like the OE tire size? Thank you.
  11. Hammersmith
    2,315
    2,354
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It will fit on the OEM wheel. No adjustments needed other than standard mounting and balancing. Unfortunately, it might not be available in the US until next year, but I'm probably not going to need new tires for two or three more years anyway.
    GeoJ likes this.
  12. GeoJ
    GeoJ Active Member
    205
    187
    United States
    2023 Prius Prime
    XSE
    This is great news, thanks for the response. I think I've found my next tire too, and can wait until it is sold in US.
    I am planning to use one of the OE tires as a spare tire when I get new tires.
  13. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    36
    Space Coast, FL
    2024 Prius Prime
    SE
    I just spent HOURS looking for something other than the silly Ecopias that came on my vehicle. Probably will get 18Kmi out of them. Looking now to be prepared. I really wanted some ultra LRR tires with decent rain traction (Florida). I thought I found them with the Hankook ION evo AS. Supposedly the best LRR, wet braking and reasonable life. The AI told me they were available in 205/60R17 - IT LIED.
    The best I seem to be able to find is a Pirelli Cinturato P7 (non run flat). Any trades in size (or using the run flat version) loses potential range because of increased LRR. I drive almost entirely on the traction battery, so my game is mainly range.
    I guess another option would be 16" rims and tires, but I'm not sure what that would look like, or if the combination of non "aero" rims (I know it's a cover) and smaller size would equal better range.
  14. Templeton
    Templeton Member
    306
    99
    usa
    2024 Prius Prime
    SE
    What is interesting and a bit odd is that Michelin cross climate 2s or 3s are available in 205/60R17, but not in the usa, just in Europe.
    I am going to try to stick with the 17s because l want to use the original wheels, as it appears that those wheel covers do indeed help with aero drag (so better fuel efficiency and better EV range).
  15. Mendel Leisk
    41,643
    That’s a new tire adjective for me, lol.
