Gen 4 Spark Plug change
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elt31987, Apr 3, 2020.
  1. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Havnt seen a thread with a walkthrough. I know some members are well past 120K. I also know that the previous Gens were a PITA due to removing the wipers and cowl. Is that the same on the Gen 4? Anyone done a write up?
  2. Mendel Leisk
    40,920
    alanclarkeau and Elt31987 like this.
  3. Elt31987
    205
    155
    Derry, NH
    Alright, looks much better than previous Gens as long as the Prime setup under the hood is similar enough to the Gen 4 non Prime. Thanks
  4. JakeCastle
    JakeCastle Junior Member
    berkeley, il 60163
    tried to change mine today. 2016 prius 3 touring. Had trouble using regular 5/8 spark plug socket, feels it's too deep. Ordered tools on amazon for extra deep sockets... wish me luck. might create a video for you tube. any one else having issues with spark plug removal? also getting confused using BOSCH 9603 vs BOSCH 9620... is there a difference?
  5. JakeCastle
    berkeley, il 60163
    tried to pull it off but this project is driving me bonkers... looks like the 9603 is for the 2016 prius c and the 9620 is for the regular prius. damn amazon had it listed wrong when i bought it a few months ago. Re-ordered plugs from amazon but prime shipping will deliver in 7 days.... Wth happened to next day delivery???!@@# damn covid. Might as well drop by the local autozone.
  6. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    Sometimes buying from a Toyota dealer (online or locally) is advantageous, as you will get the correct, or an updated, plug. For example, the Gen-3 Prius plug was updated to a hotter plug, 5 years after release, but most places still list the original plug as replacement. McGeorge Toyota in Richmond has had very competitive prices.
    If the plugs are the same size as the Gen-3, you'll need a 9/16" plug socket. I had to run to AutoZone to find one after taking off my cowl. (I believe the actual size is 14mm).
    Tande and Mendel Leisk like this.
  7. Mendel Leisk
    40,920
    Here's 4th gen Repair Manual info on spark plugs. I see the dry-threads torque is still 15 foot pounds.
    Singh Saab and pjksr02 like this.
  8. mcswell
    mcswell Junior Member
    US
    I gave up on a 2018 Prius. The wire connectors that attach to the ignition coils would NOT come off, not one of them. Tried pressing in all the likely places (I think you press down on the back end, but I tried other places as well), then push the connector towards the coil, then pull off. WD-40, screw driver to pry, etc. etc.
  9. Mendel Leisk
    40,920
    if pressing down at the designated spot doesn't work, gently pry up on the other end, right where the locking latch is, as you pull on the connector.
  10. ColoradoBoo
    ColoradoBoo Senior Member
    1,189
    775
    Monument, Colorado USA
    Thanks for posting that, Mendel....our 2017 Prius will be needing new plugs in a couple years but I may get it done sooner since it's my daughter's car and getting my hands on it for an afternoon can be an issue so I have to get stuff done when I have it!
    Mcswell: Sometimes I have to lift up the bottom of the connect with a flat-head and then use my big flathead screwdriver to coax the connector off....while trying not to break anything!!
  11. mcswell
    US
    Yeah, when I was in the Navy (I see you were in the Air Force), we had a saying: if at first you don't succeed, use a bigger hammer. But breaking something on my daughter's Prius was my worry. I wiggled, pushed, pried, prodded (and one of my prying tools was indeed a flathead screwdriver). But I didn't want a spark plug replacement to turn into a connector replacement to turn into a something else replacement. So I stopped, and I'll probably let a shop do it.
    ColoradoBoo likes this.
  12. mcswell
    US
    Thanks, I was just too afraid I'd break something. There was some kind of flimsy plastic piece, like the Greek letter pi, which pulled up easily, and then cracked. I don't think it's holding anything on, so I wasn't too worried about that. But the rest of the connector... I'm just too chicken.
  13. Mendel Leisk
    40,920
    Visual aids (our 3rd gen, hopefully similar): first off, I don't think I've noticed (or forgot), that they alternate black/white:
    Close up on the white one, just because the black locking tab stands out:
    ^ It's ostensibly a rocker, with the hinge point somewhere around the dashed line. Theoretically when you push down at the top the other end lifts up and off the locking tab. In practice they sometime are ineffective, the rocker just flexes, or doesn't completely lift off the locking tab. Then a careful pry at the bottom edge can help. I find a knife blade tip optimum for the prying, less bulky than a flat-blade screwdriver.
  14. ColoradoBoo
    1,189
    775
    I don't blame you and I agree, if something breaks the easy job just went up to the next level.
    I worked a lot with my Navy brothers and sisters, especially the Intel folks at NSGA (Now called NAVSECGRU...gotta love military acronyms!) For Iraqi Freedom, I spent a few months at Sigonella Naval Station (SIGGY) in Sicily....great place! But my favorite US Navy installation was Subic Bay, in the Philippines....great memories!
  15. Tande
    Tande Active Member
    536
    318
    Mich.
    I use these......seem to work every time.......FWIW upload_2025-9-10_0-47-32.png
    #15 Tande, Sep 10, 2025 at 12:48 AM
  16. Mendel Leisk
    40,920
    I have to rein in my propensity to acquire ever more tools, but bracing to resist: do they have a name?
  17. Tande
    Tande Active Member
    536
    318
    Mich.
    I just Google "Automotive Electrical Disconnect Pliers" .....(y)
  18. Tande
    Tande Active Member
    536
    318
    Mich.
    These also work on "ABS" connectors when replacing wheel bearings ......Again, FWIW.......
