07 Prius Aftermarket CV Axle Clicking & Popping Within 5 Months Of Replacing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fishingtimoteo, Sep 8, 2025.
  1. fishingtimoteo
    fishingtimoteo Junior Member
    Idaho
    Hello all,
    Just wanted to get some expert opinions and advice on whether OEM is necessary for replacing the CV Axles on my 07 Prius. Car has 235,000 miles on it and I recently replaced all front suspension components due to bad clicking/popping coming from front wheel hub areas. Driver & Passenger Parts Replaced--> (Inner & Outer Tie Rods, Ball Joints, Sway Bar Links, Struts & Coils, and CV Axles). CV Axles were done first on 04/28/25, with the Coils and Struts being done last on 07/11/25. Also Passenger Wheel Bearing was replaced in June 2025. Wheel alignment was done on 07/16/25. I have now developed the same Clicking/Popping from the hub areas when breaking and acceleration (Usually more pronounced on turns). If I decelerate and accelerate very slowly I can sometimes avoid any clicking or popping sounds. As far as I can tell, it seems to be more on the passenger side. In park (Car Off), when I have someone rock the car back and forth hard enough with my hand on rubber boot of the outer CV Joint behind the wheel on the passenger side I can feel the clicking popping noise and vibration from within that outer joint. Don't want to break the bank on the car because of high mileage, but am planning on keeping it going for at least 5 more years. Would OEM axles remedy this? am planning on getting some low mileage OEM axles from ebay.
    Also, bottom motor mount was recently replaced and sway bar is firm with no play and its bushings are in great shape.
    Thanks in advance for your thoughts, suggestions, and advice.
    Tim B.
  2. fishingtimoteo
    Idaho
    ....I forgot to include that both of the front Control Arms were also replaced in mid August 2025.
  3. Tombukt2
    12,924
    2,322
    I wouldn't think CV jointed would be this problematic . but sure originals are just that I've got some with 535K no noise at all boots all original n all. Get em off Southern car if possible . Most of my clunking I think is coming from lower control arms which I have not messed with but looks like bushes are shot
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,040
    1,967
    NJ-USA
    So, turn the steering wheel fully left or right and drive in a tight circle with moderate throttle (forward then reverse). If you hear a repeating metallic "click pop crack" noise, then you likely have a faulty outer CV joint in one (or both) front drive axle shaft.
    Leave the steering wheel straight, put the shifter in drive then accelerate. Stop, shift to reverse then accelerate again. If you hear a single pop sound when the car first changes direction, then there's some movement between the splines on the outer CV joint and the front hub.
    Make sure the axle nut is fully torqued to specification. Sometimes packing the splines with heavy grease before putting the axle nut on can "muzzle" the noise.
  5. BiomedO1
    3,548
    1,838
    SacTown, Ca
    Most of those aftermarket remanufactured CV axles has a lifetime warranty - so it's worth looking into. You may be outside of your mechanic's warranty period.
  6. T1 Terry
    T1 Terry Active Member
    929
    482
    Look around the nut that holds the outer CV shaft into the hub, are there bright rusty powder marks showing the axle is moving inside the hub? Possibly, that nut has not had sufficient clamping effort in the past, the hub splines are worn and that is chewing up the out CV shaft splines ....
    The other is the bolts that attach the lower control arm to the strut, if they have been loose in the past, they will have flogged out the boltholes, causing movement
    T1 Terry
  7. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    Same here. I tried aftermarket lower control arms on a Prius. In 1 yr replacements were worse than worn out oem
  8. fishingtimoteo
    Idaho
    Problem solved! Here are the details: I recently ended up buying a used oem passenger side cv axle from ebay that only had 22k miles on it---> this was to replace my already failing aftermarket cv axle. The first thing I noticed is that the oem cv axle had a counterweight on the shaft that the aftermarket cv axle did not. Upon researching, the counterweight is supposed to greatly minimize vibrations and wiggle that would otherwise travel down the entire cv axle. Once installed (around 12:30 a.m.), I took the car for a test drive. I always test drive when it is dead silent outside so I can better hear any sounds. Anyway, that did the trick. I also noticed that the oem outer cv axle joint and boot was a lot more heavy duty compared to the aftermarket one. There were no signs of damage or leaking grease on the boots of the failing aftermarket cv axle, so I'm certain the vibration and wiggle is what is attributed to it failing so quickly. In the end, from now on, I will only buy OEM cv axles for my prius.
    Thanks all!
    Hope this can help current and future prius owners!
