First DIY oil change - did I just make a HUGE mistake?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sydney2008, Sep 10, 2025.
  1. sydney2008
    sydney2008 Junior Member
    45
    Savannah
    Hi everyone!
    So, I was finally pushed over the edge by an hour-long wait for an oil change that never even happened. That was it—I decided to just do it myself. And last night, I FINALLY did! Honestly, it felt really rewarding. :)
    Now of course, I’m kicking myself for not doing this years ago. Nine years of overpriced, often shoddy oil changes (they’ve left the cap off, overfilled repeatedly, oil/filter quality, etc.)… ugh. But hey, better late than never, right?
    EXCEPT: I made a decision that might DESTROY MY CAR (whyyyyyyy????).
    There are *so many* helpful oil change videos on YT for the Gen 2 Prius. I have watched loads of them many times (and then chickened out because... jack stands, I guess?). Unfortunately, the one that I happened to use as my direct reference last night had this "helpful tip" of sticking a magnet on the drain plug... on the *inside* of the drain plug, held by magnetic force alone. Also unfortunately, I happened to have some very strong circular magnets and one of those fit perfectly on the drain plug.
    This morning I awoke feeling slightly panicked about what happens if that magnet gets loose, and my trip into the internet rabbit hole began. While there is no anecdotal evidence that this issue has happened and ruined someone's car, there was also no certainty that something like that cannot happen, at least based on my research.
    I am considering leaving Sydney (my car) in place with the engine revved for a while and then doing ANOTHER OIL CHANGE to get the magnet out before it can go anywhere. But I'm hoping I might be able to remove the plug, grab the magnet, and shove the drain plug back on before I lose a ton of oil (I have a quart in reserve, and can also get a ride for more oil).
    Can y'all please let me know what you think?
  2. dolj
    dolj Senior Member
    8,437
    4,288
    Wellington, New Zealand
    Congratulations on doing your first oil change.
    Is your worry that the magnet will unstick itself? And then what?
    Unless the magnet you chose was extremely weak, I would stop worrying.
    sydney2008 likes this.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,239
    825
    Monument, Colorado USA
    Wait, you stuck a magnet INSIDE the oil drain hole? I've never heard of that! How did you find one small enough?
    No, it will be fine...just get it out of there when you do the next oil change! (Every 6-months, 5,000 miles!)
    And great job learning to do it yourself....pretty soon, we'll be walking you through how to do a transmission drain and fill which isn't much harder, actually....getting the fluid into the fill hole is usually the hardest part but we have tricks.
  4. Tombukt2
    12,924
    2,322
    You probably will not get it out of there just thru drain . It will stick to the pan everywhere if it gets off bottom of plug it'll just be stuck to pan . Won't hurt a thing .at not get it out with out pulling pan . Auto trans have them stuck to pan bottoms all time for 60 years .
  5. Hayslayer
    Hayslayer Active Member
    390
    220
    No worries at all. The oil pan plug is steel. The lower oil pan is steel. A flat round low profile magnet is very unlikely to come loose from the plug, but if it does, it will stick to the oil pan, which is waaaayyyyyy lower than any rotating parts in the engine. The upper portion of the pan is cast aluminum. The magnet won't go there. Next time you change the oil, if you're feeling spry, clean the plug really well and epoxy or JB Weld the magnet to the plug.
    Mendel Leisk and sydney2008 like this.
  6. sydney2008
    45
    Savannah
    Thanks for all of your feedback and encouragement - I feel much better about it and I'll leave the magnet in there for now. And I'll be sure to let you know if there is any metal on it when I retrieve it in 6 months! (I've been doing 6-months, 5,000 miles changes for years - checking the work each time - and I think that's why Sydney is doing well at 247,000 miles).
  7. BiomedO1
    3,548
    1,838
    SacTown, Ca
    Just playing devils advocate here. You know the dealership is suppose to be doing a multi-point inspection when they're in there - NOT just an oil change. You should also look into what else needs to be done while the car is up on the 'rack'. Your car's maintenance manual is a good place to start. IMHO; Catching things before they break is a lot cheaper than dealing with the aftermath.
    Just my 2-cents.....
  8. Mendel Leisk
    41,384
    You should be fine, that magnet will very likely be right where you left it. That's on the end of the drain bolt? If it did somehow dislodge, it won't get far.
    Here's the oil change instruction from Gen 2 Repair Manual:
  9. sydney2008
    45
    Savannah
    Thanks, Mendel! I have the original owners manual and I could not find this information. Is the Gen 2 Repair Manual something that I can find online?
  10. Prodigyplace
    12,542
    11,767
    Central Virginia
    Good luck with that! I do not even trust my local dealer to do a proper inspection after they lied on my forst 2017 Prius inspection & tire rotation. the values they hand wrote for tire pressures were less than the required pressure. They did not change the tire pressures at all. They also were supposed to inspect the 12V battery under the hood but did not because "Prius is different". At that time the Prius 12V battery had been under the hood for over a year!
  11. Mendel Leisk
    41,384
    Honda is one company whose owners manuals have always included oil and transmission fluid change instruction. Toyota doesn’t, keeps it behind a paywall. Ditto for other things, wiper replacement for instance.
    anyway, I’ll pm you a link.
  12. ChapmanF
    18,117
    All generations can be found in the ways described here:
    Toyota Service Information and Where To Find It | PriusChat
    The page describes both direct access via Toyota, for money, as well as other avenues that can be free depending on your situation.
  13. ColoradoBoo
    1,239
    825
    And then you have Tesla who doesn't share much repair information for that extra-complicated cooling system and traction engines with anybody. (They've been sued many times.)
