2021 prime XLT Squeaky noise around steering wheel AREA
Discussion in 'Gen 4 Prius Main Forum' started by prime grip, Aug 20, 2023.
  1. prime grip
    prime grip Member
    115
    56
    SO CAL
    My 2021 Prime is squeaking around the steering wheel Area . I don't feel it at all or does it affect the steering wheel . It does get worse when driving over small bumps. It doesn't make noise when i turn the wheel at all only on bumps. For some reason i can't upload the sound off my video.
    I'm sure my prime isn't the only one.
    Thanks for any help before i go crazy.
  2. prime grip
    prime grip Member
    115
    56
    SO CAL
  3. Seb_O
    Seb_O New Member
    Wednesday
    2020 Prius Prime
    Hey did you ever find what was the problem ? I have the same exact sound in 2020 prime. And it's also driving me nuts. 3 trips to the dealership haven't produced any significant improvements. I found that if you hold the brake pedal with your foot (from the backside), the noise goes away. Anyway, hope you found out a solution !
    Thx !
  4. ocean view
    ocean view Junior Member
    33
    Western MA
    2022 Prius
    Did you try unlocking and repositioning steering wheel?
    #4 ocean view, Sep 11, 2025 at 7:34 AM
