Obd2 quit working, need advice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Keissel1, Sep 10, 2025.
  1. Keissel1
    Keissel1 New Member
    Hey guys, just wanted some opinions on my car situation.
    2005 prius, having some issues, and of course now my obd2 scanner won't connect to Dr. Prius. First off i had a faulty rear brake pad come off and locked the wheel up. At low speed thank god. So I had the warning brake lights on. Tried to reset them using the paperclip method to no avail. Soon after I began experiencing the usual bad module code, and a few weeks later I received the code where there is a high voltage short to ground (don't remember the code).
    So I finally got some time to work on the car, and now I can't use Dr. prius. It just doesn't show up in the app to connect to. I have cleared all of my bluetooth devices, restarted my phone, tried it with the car running, not running, ready mode, just never comes up. I have the Panlong obd2 scanner that is recommended on the Dr. Prius website. I know it's not as great as techstream, but it has been good enough for me until now.
    Has anyone had these devices just quit working? It still lights up, and has a constant red light while plugged in. Also it is probably around 8 years old, maybe 10 I can't remember.
    So also if it's not the obd2 scanner, does that mean that I messed up the plug by inserting a paperclip into 2 of the holes...
    Since this has worked for me for the last 8 years, has there been any updates to which obd2 scanner works better nowadays? I realize a simple option to test the port is to buy another one, but just wanted to hear from folks if I should purchase a different one before buying the same old one. Or has the Dr. Prius app became obsolete? Or am I missing something super simple that I can't remember... idk
    Any advice is appreciated thanks.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,591
    768
    Southern California
    Plug the OBD2 dongle into another car and see if it works there. The dongles do go bad sometimes, as can the port in the car. I suppose it is even possible that the bluetooth circuity on the phone has failed. So having positive control is useful in figuring out where the problem lies.
    Brian1954 likes this.
  3. Keissel1
    Keissel1 New Member
    Definitely agree with that, just have never used it in another car. Or another scan app for that matter. Shouldn't be my phone because I am able to connect to other devices via bluetooth. Will be a process of elimination I suppose. Hoping its just the obd2 scanner, don't even wanna think about replacing the actual port...
  4. dolj
    dolj Senior Member
    8,434
    4,285
    Wellington, New Zealand
    Just to be clear, this item is an OBD2 interface device, not a scanner. The colloquial term for an interface device is a dongle.
    The scanning happens using the software that you install on your device (phone/tablet) that interfaces to the dongle via Bluetooth (or sometimes WiFi).
  5. Keissel1
    Keissel1 New Member
    Gotcha, thanks. Yea I tested the dongle in 2 other cars, didn't show up for me. So I'm going to assume that the dongle is the problem. Will probably be ordering the same one unless anyone body has input on a better one.
  6. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    From what you have, I suspect (the very least) you blow the fuse when you paperclip your jumper.
    Check the obd fuse ( #8 ?) and replace if it blown.
    For check out to make sure, bring it to Kragen/reily ... if they can read it, then your OBD2 gadget is bad :)
  7. Keissel1
    Keissel1 New Member
    I thought that too, but was getting power to the dongle because they lights were on. But also checked the fuse and checked out good with the multimeter. I think I just assumed because it wasn't working, and its worked every time for ~8 years, that I potentially ruined the port. Going to buy another one and try it out.
  8. Priusguru81
    Priusguru81 New Member
    York
    2014 Prius c
    Check the fuses as recommend by others. Also a great scanner that is full system and works on Prius is the Youcanic full system scanner. It has an option to check the OBD2 port operation. I have it on mine too. Can help you check yours for sure. I saw a yt video on that as well. Look it up.
  9. Brian1954
    Brian1954 Senior Member
    2,167
    843
    South Central PA, USA
    How much did you pay for that scanner?
