87km’s on a Single Charge
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by Toyotaworker, Jun 29, 2025.
  1. Toyotaworker
    Toyotaworker New Member
    2024 Prius Prime
    I’ve been taking screenshots as the EV mileage range keeps going up. So it shows 87km’s of range on the app but does it actually get that…..
    Yes it does
    Exceeding the 72km’s…just thinking about the new Rav as it’s rated for up to 80km’s I’m sure it will also go above the actual range
    Quovadis007 and bisco like this.
    52,328
    screenshot?
    Toyotaworker likes this.
  3. Toyotaworker
    2024 Prius Prime
  4. bisco
    52,328
    fantastique!
  5. Quovadis007
    Quovadis007 Junior Member
    COVENTRY
    2024 Prius Prime
    Business Ed. Plus
    The EV range of my Prius Phev 2024 in the Toyota App (= ditto in dashboard), increased to 105.1 km  with air conditioning this would be “only” 101.9 km, with defensive driving style.
    The air conditioning runs about half the time, because the car leaves a garage, I end up getting about 95 km EV kilometers, on 1 full battery (11.4 KWh charging), on local 50 to 80 km/h roads. With lights and certainly rain / windshield wipers, this drops quickly. On the highway with +80 km distances, I drive in Auto Ev mode and Predictive drive in the navigation system.(hybrid with ev assist)
  6. MSantos
    MSantos EcoAccelerometry
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Nice indeed.
    Mine has been going up for most of the spring and summer, and at this pace perhaps I might be hitting the 100km range in another month or so. On the other hand, mine is the slightly heavier and less aerodynamic trim, so I would not be surprised if I don't quite make it. LOL.
    Never dull.
    Screenshot_20250714_120320_PrimeXSEPremium.jpg .
  7. Toyotaworker
    2024 Prius Prime
    Up to 90 today. FYI I have yet to turn on the A/C in this car the fan blows cold enough as it is anyone else have the same experience IMG_0548.png
  8. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just letting you know that your A/C has probably been on this entire time. Unless you went into the climate settings early on and set "A/C on AUTO" to OFF.
  9. Toyotaworker
    2024 Prius Prime
    Not sure about that because it definitely doesn’t affect the mileage outcome & I hear no compressor
  10. MSantos
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Instead of creating a new thread, I just shamelessly revived the OP's instead for a follow-up.
    At the rate my projected e-range has been inching up in the last few months... and it is still climbing... I admit to be a little surprised and curious at the same time.:cautious:
    While it is still 2KWh/100km less efficient than either of my 4th Gen Primes, its still better than what I expected just a month ago.
  11. bisco
    52,328
  12. Zeromus
    Zeromus Active Member
    553
    308
    Ottawa Canada
    2024 Prius Prime
    SE
    Ours is around 92km with the AC on with it off it reads 99km in the car. The prime SE with the 17 inch wheels really does get a great range.
    Now if only it was RATED at 100 instead of 75km, then winter we'd probably see closer to 75, better than 65 we get in winter here lol
    I'm happy to take the summer range being so good though. More than makes up for the needing to use the engine more in the winter.
  13. Pripri Prime
    Pripri Prime New Member
    Montreal, Canada
    2024 Prius Prime
    XSE
    Hi guys,
    How do you do it? Mine hasn't gone more than 72kms of range. Is it something to do with the driving or the car adapts the range by itself...
    Cheers.
  14. Quovadis007
    COVENTRY
    2024 Prius Prime
    Business Ed. Plus
    Since July, the EV range has increased to 110 km or 68.3 miles.
    This is only possible in light city and local traffic without rain or air conditioning.
    On the highway, I drive in Auto/EV mode.
    19" tires
  15. MSantos
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    The results we get are heavily dependent on use cases and variables (variables we can can control, and those that we cannot).
    With reasonable use cases, it is also rare for me to recall an example where a well maintained Toyota hybrid or Plug-in cannot produce higher efficiency numbers.
    I can summarize my use cases as follows (for Gen 4 and Gen 5 PHEVs):
    • Primarily urban and suburban defensive driving EV only (90%).
    • Occasional highway driving in HV only, at speeds > 80KM/h or 50M/h (10%).
    • Regular choice of commute times and itineraries.
    Summer-Time Variables (the variables I can control):
    1. Minimize, or even avoid, regenerative braking whenever possible. To achieve this safely without becoming a traffic obstruction, requires maximal awareness and a great deal of "opportunity". This is something I often do (like choosing commute times, using less congested itineraries, real-time traffic reports, etc.).
      While the algorithm heavily favors the return of range on regen, the longer a glide pattern is with no regen or even a minor assist, the better the efficiency outcomes.
      This is the MOST significant variable for me as every other benefit is "downstream" from it.
    2. If possible and safe to do so, keep the power draw for accelerations well below 40Kwh/100km. After that, maintain steady state driving as much as possible.
    3. Set the climate control settings so that on average, it does NOT draw more than a single digit percentage of the usable range. It is definitely possible to get high efficiency numbers while remaining comfortable by setting the AC to 1-2 degrees below moderate ambient temperatures. For an even better way to manage this, use the Hybrid Assistant (Gen 4) or Car Scanner apps and make sure the current draw when at a stop light and AC ON, is in the low single digits (1-3 Amps).
      If we observe and manage this regularly, then the estimated ranges for AC versus NO AC will eventually become very close.
    4. Keep tire inflation between 37-39 Psi (cold measurement). To me, it has long provided an OK balance between rolling resistance and passenger comfort.
    5. Keep the 12V battery healthy by regularly plugging it in to a good battery maintainer. The point here is to minimize the effective load on the DC-to-DC controller while the car is in READY mode. While regularly maintaining a 12V battery is highly recommended for those in northern climates, (duh !), it also pays some dividends over the summer months too.
    6. Finally, I always get a wheel alignment on delivery, and then every so often depending on the quality of the roads. Dropping into a few big pot-holes now and then should be a good reason to schedule an alignment.
      This is because minor alignment deviations can cause measurable losses and unnecessary tire wear, even if it is not noticeable to most drivers. As always, a well aligned car glides farther with lower drag.
    Lastly, have a look at any eco-driving or hypermiling toolkits and it is likely there will be some advice in them that is safe, and palatable to you and to those sharing the road with you.
    Just my two cents.
  16. Gokhan
    Gokhan Senior Member
    6,490
    2,595
    Paramount CA
    I typically get 64 km (40 mi) on a single charge in my Gen 4. That would correspond to about 117 km (73 miles) for Gen 5’s battery size.
    MSantos likes this.
