Engine Vs Battery Miles Driven Breakdown Data
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dave1UK, Sep 11, 2025.
  1. Dave1UK
    Dave1UK Junior Member
    66
    London, UK
    Active
    Is there a way to find out how many miles was done on the electric battery only and how many miles was done on the engine itself for the lifetime of the vehicle?
    52,393
    it may be in the black box, but that is only available to toyota. there isn't anything for the driver in gen 3
    Dave1UK likes this.
  3. BiomedO1
    4,148
    2,173
    SacTown, Ca
    On a plug-in; there's usually a % of battery, EV vs HV operations buried in the user menu screen somewhere. I haven't seen a UK menu option, but that's how a gen4 is laid out. You'll need to extrapolate from there to get a ball-park number.
    One thing to note; If the aux. battery is disconnected that historic % will restart at zero again - at least on the software on this side of the pond. You should also be able to manually reset the calculations to zero - I accidentally did that while exploring all the menu options on mine.
    Hope this helps.....
    Dave1UK likes this.
  4. bisco
    52,393
    ah! i missed the plug in. my gen 3 had an ev/hv ratio screen
    BiomedO1 likes this.
  5. Dave1UK
    66
    London, UK
    Active
    Would have been interesting data to see. See actual "wear" on engine.
    Unfortunately don't own a plug-in but good to know for future ref. Thanks.
  6. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Wasted extra curricular reading on my end also. Might as well get some 4thb and 5th gen Prius feedback also.
    Dave1UK likes this.
  7. Mendel Leisk
    41,907
    Why do you want to know, to stretch the oil change interval, or?
  8. Dave1UK
    66
    London, UK
    Active
    Well knowing what I know now of hybrids if there was a way to determine engine vs battery mileage (i.e. wear) it may have swayed my choice of car when purchasing.
    These are my assumptions:
    A Prius which would have been used as an Uber/Taxi etc would mainly be driven shorter distances and lower speeds (for the UK anyway in London) so would assume higher battery wear as opposed to engine.
    On the other hand a Prius driven to work several miles away daily on the motorway would have a greater engine wear as opposed to the battery?
    Think the data would be good to know for second hand vehicles.
    bisco and Mendel Leisk like this.
  9. bisco
    52,393
    then again, these batteries like to be used. it's the half million mile taxi's that still have the originals
    Dave1UK likes this.
  10. Dave1UK
    66
    London, UK
    Active
    Indeed, personally I'd go for a heavily used battery as opposed to engine. Easier to replace/could argue cheaper in some instances.
