I had to jump my 12v battery today - How do I maintain a healthy battery?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Resilient, Apr 3, 2024.
Tags:
  1. thompsam
    thompsam Junior Member
    Raleigh
    I did indeed take it into the dealer.(of course the battery was once again dead the morning of my service appointment). My 6 month service was due and I asked them to check the battery while it was at the dealership. Turns out the battery was indeed bad and it has been replaced. Thank you dealership
    While I was there, I did ask them if there was a way to put the car in some sort of sleep mode which would keep any of the background processes from running and sadly, the answer was no. The only suggestion the master mechanic had was to store the key fobs some distance away from the car, but there was no real definition of far away was sufficient.
  2. bob12345
    bob12345 New Member
    22
    Knoxville, TN
    2024 Prius Prime
    SE
    You can disable the key fob in order to reduce the car from wasting energy trying to detect the key. While holding the lock button, press the unlock button twice and release both button. Car will lock and red light will blink two times quickly then another two times quickly. This puts the key fob into "Sleep mode", not the car, but it should help if you keep the fob within sensing distance of the car.
    I had my car at an airport parking lot for 6 days and no issues for me, but I didn't measure the 12 volt battery.
  3. SXP
    SXP New Member
    25
    Huntington Beach, Ca
    2025 Prius
    So, is the consensus not to leave the battery connected to a smart charger when not in use - say for a month?
  4. Mendel Leisk
    41,056
    I’m bucking that trend.
  5. thompsam
    Raleigh
    How does one "wake up" the keyfob? Just normal use? I have tried wrapping a key in aluminum foil and it seems to "hide" the key from the car. Even when directly beside the car, it doesn't unlock like normal.
  6. SXP
    SXP New Member
    25
    2025 Prius
    I'm specifically referring to the 12V battery on a non-Prime Prius - so, you have no issues leaving it on a smart charger indefinitely? I'm going to be gone for six weeks and was going to leave it on a Battery Tender until I waded through this thread and now have mixed feeling about doing so.
  7. Mendel Leisk
    41,056
    For 6 weeks I’d also consider just disconnecting the negative cable. Yeah, we did a drive today, believe it’s been 2 weeks, steady on the charger. A CTEK FWIW.
    otatrant likes this.
  8. bob12345
    bob12345 New Member
    22
    Knoxville, TN
    2024 Prius Prime
    SE
    To wake the keyfob, just press any buttons. Before you wake it, you can verify the fob is disabled by trying to start the vehicle. If the vehicle does not detect the keyfob, then the fob is in "sleep" mode.
