Are there any speakers for 2020 Prius thst go 20 hz to 20 kHz? I won’t buy new speakers that all seem to show crappy freq range like 60-18 kHz or so. And subs even show 45 hz or even worse. I’d prefer door speakers at 20-20 or at least not so crappy like 45-60 hz. For a sub I’d want one 10 inch ported 20 hz. Not crazy power tho im not into that. Just normal Electronic.
It wouldn't surprise me if the drivers listed with "crappy freq range" were just advertised more honestly than some more "impressive" ones. Maybe it's easier to get good reproduction in a car cabin by using what drivers are available and setting EQ empirically?
Eq takes away from the intent. I do t change it. It’s always set 0. I find it pathetic if a so called sub goes to only 45 hz. That’s not sub. Sub is sub bass. Low. 45 ain’t that. And for door speakers to only do 60 hz is pathetic too.
