Serious questions about the solar option available in the Prime:
Discussion in 'Gen 5 Prius Main Forum' started by NonFormulaic, Aug 14, 2024.
  1. Gokhan
    Gokhan Senior Member
    5,893
    2,320
    Paramount CA
    They make it, and I think it is a great option if you normally park your car under the sun. Why waste all that energy if you can use it?
    You should also only opt for the extra-cost, tricoat white or silver if you go with the solar roof, as the car would get too hot under the sun otherwise. They are the best Gen 5 colors anyway, in particular the extra-cost, tricoat white.
    No, the Prius PHEV does not come with AWD. But then, why would you need it in Florida?
