Detailing: Wash and wax/sealant or ceramic coating
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by daisy555, Sep 3, 2025.
  1. daisy555
    daisy555 Senior Member
    1,700
    698
    CT
    My car exterior needs a thorough cleaning. We aren’t allowed to work on our cars in the parking lot plus I would need to wear a respirator. More than I can handle right now.
    I found two professional detailers with good reviews but they use very different products. One is offering a 5 yr ceramic coating for $900 using Augalux products and a yearly boost at $50. Another is offering 3yr coating for $900 using System X with yearly $150 boost. He’s sending me quote for 5 yr. I know I would need to wash still. These prices are not including paint corrections since as far as I can tell that’s not necessary.
    Both places charge $200 for a wash and wax or sealant. This quote doesn’t include interior because I can clean that myself. Seems to be the going rate near me. We don’t have any drive thru touch-less near by.
    Sounds like it would be more economical over the 5 year period for me to do ceramic coating although one guy said ceramic coating requires more maintenance washing?? I could rinse and/or wash when I can but winter would be challenging. Unfortunately my car sits out in the sun all year round.
    Any suggestions? I’m pretty sure this topic was discussed but I can’t find anything right now. Thanks
  2. 10^123
    10^123 New Member
    US
    2024 Prius
    Limited AWD-e
    I had a few looks at ceramic coating when getting quotes for PPF. It looked to me like snake oil. Went the PPF route. If you do get ceramic, let me know if it's really worth it.
  3. Mendel Leisk
    40,926
    All I can think is “someone’s always finding a new way to to extract money from folks”. I’d categorize this with dryer sheets, pedicures and so on.
    Is there no way you can just wash an’ wax the car? It entails a wash bucket and sponge, bottle of car wash liquid, bottle of liquid car wax (aka “polish”, typically come with applicator pad), and some flannel cloths for buffing (soak in dilute ammonia after, with a bit of soap, rinse and wring out thoroughly, then add to laundry load).
    You’re dealing with condo rules? Any way you can access a driveway and hose, preferably someone’s carport?
    “Respirator” has me thinking I’m trampling around in Chris Farley mode, let me know.
    #3 Mendel Leisk, Sep 15, 2025 at 8:13 AM
  4. BiomedO1
    3,063
    1,627
    SacTown, Ca
    I'm not that particular about my paint; as long as it looks half-way decent.
    The price seems high, though I guess labor cost is high these days.
    I detail my car annually and do a ceramic coating - not that expensive marketing bougie stuff - I do it myself. The benefit is that all I have to do is hose-off and maybe use a brush on the car, then dry it. Any stubborn stains gets the brush; then a spray of ceramic waterless detail; to restore any lost coating. I don't get really harsh weather here and they only sand the roads when needed. The worst I get is when they're repaving roads. Most tar will wash-off/rinse-off with that ceramic base coating.
    I had some nasty water spots once. Had to polish the entire panel and recoat it. Don't park near automatic sprinklers.
    YMMV
    #4 BiomedO1, Sep 15, 2025 at 11:58 AM
  5. Mendel Leisk
    40,926
    Or at surprisingly free and convenient parking spots, under "certain trees"...
    #5 Mendel Leisk, Sep 15, 2025 at 12:15 PM
  6. BiomedO1
    3,063
    1,627
    SacTown, Ca
    :LOL::ROFLMAO:o_O
    Then I'm dealing with hood and roof stains:mad::(
    We have a lot of trees around here that are infested with aphids. Those droppings are like pin-head tree sap - they really stick to hot car surfaces.
  7. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    34
    Space Coast, FL
    2024 Prius Prime
    SE
    Take a look at using a "rinseless wash". Optimum No Rinse is one such product that get tons of props in the detailer blogs online. It's a polymer cleaner. I use it a lot and it gets better every time I use it. Regardless of that, you'll still have to wax it, put ceramic on it, or use something like ICON Rockclear (like additional clear coat). Wax is cheaper, ceramic is very slick, ICON works but expensive. If you do the ceramic yourself you'll need to prep the surface and use a polisher. The detailer world has holy wars about all these things so I won't really get into it. Like stated previously it depends how long you plan on keeping it. No matter what if you want to protect it you'll be washing it every two weeks. There are all kinds of products out there and it depends on your level of involvement with your car. There are also plenty of "hybrid" cleaning and polishing products out there. One for example is Turtle Wax Hybrid Solutions - it's a bit gimmicky with "graphene", but it gets a lot of really good reviews. It's not the same as a ceramic coat, but it may work out good enough. It's a big, crazy, multi-opinioned world out there for paint care, just pick something and see how it goes.
  8. VirginiaLeePrius
    34
    Space Coast, FL
    2024 Prius Prime
    SE
    Heck, don't forget the water you use also contributes to staining, I have to used 5 gal containers of water that has been run through an RO machine and which is soft. My water at home is sulfur and hard water. Even rain water can be an issue. Again the ONR helps me a lot here.]
  9. Mendel Leisk
    40,926
    That’s a little presumptive, lol. Depends a lot on usage, location, weather, storage conditions.
  10. BiomedO1
    3,063
    1,627
    SacTown, Ca
    I've got a whole house RO system in place, behind the gardening water bypass. I have a choice of using hard or soft water.
