Brake Master Cylinder interchangeability
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by EzC, Aug 29, 2025.
  1. EzC
    EzC New Member
    Durham
    2014 Prius v wagon
    I’ve seen some other threads touch on the topic but wanted the most up to date knowledge. I have a 2014 Prius V five with a failed Master Cylinder and Actuator. Which Master cylinder part numbers are compatible? Toyota parts lists 47110 and 47260 but could I get away with slapping the much cheaper 2015+ master cylinders in there and if so which ones? Are they not backwards compatibles due to newer features such as the radar cruise control and such?
    Also could someone finally clarify, the two things I have to replace are the brake actuator and master cylinder right? Does the accumulator overlap with this?
  2. rjparker
    10,412
    6,521
    The brake actuator and master cylinder are one item. It is on the left.
    Depending on what Toyota parts site you visit or which Toyota doc you are reading it is called a Brake Booster or Master Cylinder Assembly. It has the Skid Ecu inside and software in that ecu changes the part number. Every Prius v is different from any hatchback even in the same year. If the Prius v in 2014 has 17" wheels it has a different Master Cylinder Assembly than a 2014 Prius v with 16" tires. Get the wrong part number and it won't work. To complicate things they all have the same housing number embossed in the case which makes salvage yards think they are all compatible.*
    The only sure way to get the proper part number is using the vehicle vin. A Toyota local or online dealer can look it up. Some Toyota online dealers websites can drill down based on model, year and trim. Or you can message them with your vin.
    The (Accumulator) Brake Booster Pump or simply Pump Assembly on the right is more generic on gen3 hatchbacks and v's as it has no control built in. However these days it is rarely the problem.
    The following captures from an online Toyota dealer represents parts needed for a 2013 v.
    * If you wanted to risk installing a used Prius gen3 Master Cylinder you would need the donor car vin to verify its part number.
    #2 rjparker, Aug 30, 2025
    EzC likes this.
  3. EzC
    EzC New Member
    Durham
    2014 Prius v wagon
    So to make sure I'm understanding this right, should I replace both the accumulator and master cylinder since I'm already in there or just the master cylinder? The frequent leaking/hissing sound; could be heard roughly every 10 seconds and braking instance up until eventual failing and when it subsequently totally lost abs. Would this be the accumulator failing due to leaking valve inside the brake master? Or is that the inboard brake master cylinder's booster failing? As toyota currently has a 25% off parts sale I'll probably just buy Oem Toyota and eat it as this car has treated me fairly well and my other Prius V seems to be luckily immune to this issue after 280k miles.
    Also there is at least one gasket I have to replace while doing this right? Will they come with the parts order or will I have to get them separate?
  4. ChapmanF
    18,458
    You might want to scan the service bulletins about Prius v brake issues to see if there was a replacement assembly mentioned with a part number starting with 04something. Those part numbers are 'kits', which Toyota sometimes creates to go with a service campaign, where the kit might include other stuff (like gaskets) that would normally have to be ordered separately. Also, oddly enough, the kit price is often better than the price under the original a la carte part number.
  5. rjparker
    10,412
    6,521
    I would replace both which is what a dealer would do. However many replace the master cylinder assembly only.
    If you are doing this diy and buying online, find an online Toyota dealer with a good price and free shipping (they vary greatly) and send a message with your vin asking what part number(s) and gaskets.
    I believe many reuse any clamps and the brake lines are flare fittings. Based on the diagrams it looks like the pump/accumulator comes with two bushings and collars used to mount it.
    If you are planning diy, be prepared for the special flush and calibration procedure typically sequenced with Techstream. Many have issues on that step.
    #5 rjparker, Sep 15, 2025
  6. EzC
    EzC New Member
    Durham
    2014 Prius v wagon
    I found the TSB T-SB-0089-20 for my model year, it says the master cylinder 47050-47260 becomes 04009-79247 & accumulator 47070-12020 becomes 04006-22212. I however cannot find those 04 kits on toyota's actual parts website. Are they only available third party or at an actual dealer or something?
    In regards to Techstream, any VCI cable recommendations? Would a cheap chinese one work? I've seen comments on included malware on the cable's drivers and techstream copies, would this be remedied by just finding untampered with software online? If not should I just bite the bullet and get a mongoose or get it trailered to a mechanics for just the bleed procedure?
    #6 EzC, Sep 18, 2025
  7. rjparker
    10,412
    6,521
    People have lots of trouble with the after replacement special flush procedure. Personally I would have somebody do it.
    If you review the "ID Proper Parts with Vin" attachment above, Toyota instructed the dealers to look up your part number by vin and then cross reference to the kit. There was a kit at one time when they were changing these free. The only way to know is to message the selling dealer.
