Does heat make the hybrid battery deplete when not used?
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Sep 15, 2025.
  1. Prius92
    Prius92 Active Member
    592
    122
    Iowa
    Drove 75 miles Saturday, parked and battery was 2 bars away from green.
    Did not drive my car yesterday, was 95 outside.
    Got it in today and the battery was so drained it moved like a snail until it charged up. Drove just fine after that.
    Did a health check and all that with Dr. Prius. No issues.
    52,093
    yes, especially an old battery was it parked in the sun?
  3. PriusCamper
    PriusCamper Senior Member
    12,844
    5,204
    Pacific Northwest, USA
    This is a known problem of old Prius, especially when pack gets old and looses capacity and needs deep cycling to restore capacity.
    Also corrosion builds up from the hybrid battery in the battery ECU and you may be able to eliminate this symptom by cleaning the pins where they solder to the board inside the battery ECU.
  4. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    Time alone does a decent number on it. Heat hurts more in usage- but it's never good.
  5. Prius92
    592
    122
    Iowa
    Oddly, I did notice the day before it went flat, my MFD was showing a lot more "cars" meaning a lot more regeneration going on, and it was the normal route.
  6. PriusCamper
    12,844
    5,204
    Usually when people notice more reg (cars) than normal on the screen and post about it on here it eventually turns out to not being related to problems, just creates confusion more than anything.
  7. Prius92
    592
    122
    Iowa
    Ya I'm kinda at a loss. It's only done it once before this year when it sat parked a couple days in like 95-98 degree heat.
    It worked fine again today.
