spike in EV range?
Discussion in 'Gen 5 Prius Main Forum' started by GeoJ, Aug 16, 2025.
  1. GeoJ
    GeoJ Active Member
    217
    198
    United States
    2023 Prius Prime
    XSE
    My EV range on the dashboard after I fully charge is 43, sometimes 44 in warmer weather (drops to around 35 in winter). This morning, after a full charge it jumped to 49! Why would it have such a big jump in just one day? If it crept up to that level I would believe it, but don't understand why it would jump from 43 to 49 with no other changed factors that I am aware of.
    52,386
    was the hvac including fan off?
    has your driving been any different lately?
  3. Hammersmith
    Hammersmith Senior Member
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I can think of 3 general possibilities:
    1. Today was different for some reason. HVAC, temp, last night's charge, etc.
    2. There was a really bad day in the history that just aged out.
    3. Software update overnight that changed some parameters.
    If you forced me to guess, I'd wonder about a combination of 2 & 3. Maybe there was an update that had a side-effect of clearing out your driving history. So instead of looking back at however long it usually does(maybe a couple weeks or a couple months), it only had a snapshot of today's conditions. But that's totally a guess.
    GeoJ likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,053
    5,304
    Pacific Northwest, USA
    These are just estimates... Don't take them too seriously. And as mentioned using your HVAC is going to massively change your EV range, so even just a tiny bit of use or non-use will change those estimates.
    Danno5060 and BiomedO1 like this.
  5. BiomedO1
    4,126
    2,168
    SacTown, Ca
    Don't get too excited; those are just estimates based on your recent past driving style. As it gets colder, those estimates can easily go the other way.
    Danno5060 and PriusCamper like this.
  6. GeoJ
    GeoJ Active Member
    217
    198
    United States
    2023 Prius Prime
    XSE
    Perhaps HVAC off, but not for long, although I guess that is possible explanation. No change in driving.
  7. mva
    mva Member
    154
    92
    B.C. Canada
    2024 Prius Prime
    SE
    You can turn hvac on and off and watch the range change.
    PrimeDan, GeoJ and Danno5060 like this.
  8. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    It is just an estimate based on recent trips, current battery temperature, AC etc.
    I tend to use the % remaining indicator as it is more helpful, and I can guess range more precisely.
  9. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    44
    Space Coast, FL
    2024 Prius Prime
    SE
    Mine has slowly risen from 44 miles to 58 miles now. I attribute to several things, the tires wearing (I have almost 10K miles now), the extreme Florida heat stirring the electrons in the batteries, and my almost religious use of Automatic Cruise Control (ACC). My miles are in town, when I run the AC, radio, etc... it loses about 4 miles. I set my cruise for 51mph, but most of the time it's not even close with traffic. I've seen someone here report 60 miles so when I get in I always cross my fingers. I'm soooo happy I decided on the PHEV. Good luck with your range, I suspect it will improve, especially after about 2000 miles on your tires.
    PrimeDan and bisco like this.
