Traction battery to be replaced?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lpf, Sep 15, 2025.
  1. lpf
    lpf Member
    139
    39
    Greece
    The traction battery drains quickly when I accelerate aggressively, but then charges normally.
    Keeps energy well when driving calmly. What you thing, is this time for total or partially replacement
    of modules?
    Thanks
  2. Tombukt2
    13,447
    2,418
    Could very well be have you ran the doctor Prius advanced test or any kind of advanced test on the hybrid battery there are several programs? I don't know them all. How about just not beating on it . I'm sure this is with everything on AC and all that stuff so you know. It is summer . Energy storage do not like hi heat. So if you can't live with it then yes you can play whack a mole or replace factory .
  3. bisco
    52,396
    how is gas mileage?
  4. lpf
    lpf Member
    139
    39
    Greece
    Around 44mpg. No big difference.
  5. lpf
    lpf Member
    139
    39
    Greece
    Checked with Dr Prius, around 70%. But battery can't cope with acceleration and high speeds...
  6. bisco
    52,396
    you could try a grid charger
