Is Buying a Gen 2 Still a Viable Option?
Discussion in 'Gen 2 Prius Main Forum' started by c.ortiz108, Sep 10, 2025.
  1. c.ortiz108
    c.ortiz108 Junior Member
    98
    22
    San Francisco, CA
    Just had a reply that the battery is not OEM and was installed by a regular mechanic. No other info and no service history beyond 2016. So I think I'll pass on this one. The 2007 for $3,500 was an OEM Toyota-installed battery, but a year older and a lot of miles....
    I'm test driving the Corolla this afternoon, but part of me is thinking if I'm going to go that route, for another $1k I can probably get something with significantly fewer miles than 214k. @rjparker would you have many qualms about a Corolla with that many miles for long trips? (assuming a mechanic gives it a green light).
  2. pasadena_commut
    pasadena_commut Senior Member
    2,436
    730
    Southern California
    The qualm is not knowing how the car was treated during that time. If it had perfect maintenance then go for it, the car should be good for many more miles. (Although for some Corolla years expect the sides of the front bumper cover to pop loose - they used a crappy method and one side or the other of the clip mechanism is broken more often than not. The cover itself is fine.) If the car went 15k miles between oil changes, or severely overheated even once, then it is a disaster waiting to happen. Ideally you find a car with one owner who can give you the folder containing every single service record for the life of the car.
    c.ortiz108 likes this.
  3. c.ortiz108
    98
    22
    San Francisco, CA
    The one I just drove was a piece of junk. Rumbling and rattling like the engine was about to drop out. And so filthy I feel like I need to go to a NASA decontamination unit. It put the fear of god into me about older cars
  4. Leadfoot J. McCoalroller
    7,986
    7,466
    Pennsylvania
    2018 Prius c
    But you have to compare that to the possible cost of the Prius throwing a $1,500 fit on the way back from one, costing you towing and hotel time while you figure out what to do.
    ...and that's after you've spent the money to actually buy it.
    Point is, you absolutely cannot look at the purchase price of the car as the last major money you'll spend on it unless it is a new or very young used car. You're getting on a treadmill.
    The fundamental difference between an old Prius and and old Corolla is that every mechanic in every town (including the cheap ones) knows how to work on a Corolla. That alone makes the Corolla a much safer choice when looking at the oldsters. You'll never save enough gas with a Prius to make up for the extra costs associated with its technical sophistication.
    97trophy likes this.
  5. Tombukt2
    12,654
    2,253
    Yeah that's right if you don't work on stuff and have a general like for how things work and so on and so forth yes stay away from a Prius buy your Corolla the to me the earlier the better the 2zz engine is in them it can have issues . Anything after 10 in Toyota is heading downhill for me . Compared to last 40 with Toyoda for me. My 93 to 02 Corollas will Outlast everything any of y'all drive . I've got 500K on a few of them and they're rt here driving bno body damages or rust just faded . Interiors are solid no rips . They will run forever the 7Afe and 1zz easily make 400K . No weird computer to fail no of it . But they hard to find clean and acceptable at least for y'all.
  6. T1 Terry
    T1 Terry Active Member
    887
    456
    Agreed, an old Toyota can be fixed by just about anybody with a spanner, the later models, once they added computers and fuel injection and the likes, you need someone who knows what they are doing, and a wallet ready to be emptied.
    A Gen 2 Prius is a great mechanically minded person's runaround car, there is a You Tube video to fix anything that can be fixed on them, but if you aren't handy with spanners and have a mechanical aptitude ...... the whole rental idea might be a better option ...... a motor vehicle is just a method of draining any finances you have available, much like having a child, but at least they don't slam doors or kick up a racket when they are ignored ;):whistle:
    T1 Terry
  7. c.ortiz108
    98
    22
    San Francisco, CA
    Okay, I guess I'm going back to the plan of coughing up the money to get a Gen 4 :LOL: But will also keep an eye out for Corollas.
    ...Or maybe an Ioniq or a Niro if they have low enough miles and I like how they drive. The Niro especially has some great reviews, is supposed to be dependable, and tend to have lower miles, lower prices, and more available compared to Gen 4s. On Monday I'm test driving a supposedly immaculate 2019 with only 49k miles for $12k, which is quite a bit below KBB.
  8. hill
    8,721
    Any car you buy that may be past or near a ΒΌ Century old could have issues. It's apples to apples
  9. ColoradoBoo
    ColoradoBoo Senior Member
    1,191
    780
    Monument, Colorado USA
    Have you considered an older Avalon? I've seen some out there, 12-15 years old, going for reasonable rates.
    And I agree with that older Corolla suggestion....my old 2008 Corolla is, still, chugging along, going on 200,000 miles (ex-son-in-law drives it now but I maintain it for him....he doesn't know the difference between a Philips-head and a flat-head! :)
    Same goes for a Toyota Matrix...if you can find one for sale, definitely check it out! (I think the Car Care Nut said it's one of the hidden Toyota gems, "indestructible")
    97trophy and c.ortiz108 like this.
  10. c.ortiz108
    98
    22
    San Francisco, CA
    The Avalon would be too long for my driveway. My sister used to have a Matrix and she liked it. They don't as good mileage as a Corolla, though.
  11. pasadena_commut
    2,436
    730
    Southern California
    As far as I can tell (based on an eyeball survey of the few I see in my neighborhood) the only people who own and drive Avalons are fairly well off, as in can afford to do regular maintenance, but don't drive much. Those cars are built like tanks. (They also have a backup/alarm that powers and sounds the horn if the battery is disconnected, which can be quite a surprise for somebody who tries to work on one without knowing about this ahead of time.) They only get 30ish MPG on the highway, but I'm about 99.9% confident that a long trip in an Avalon would be much quieter and more comfortable than in a Prius. Because the Prius is pretty loud inside at highway speeds and while the seats are OK, luxurious they aren't.
  12. Leadfoot J. McCoalroller
    7,986
    7,466
    Pennsylvania
    2018 Prius c
    At 5,000 miles per year, fuel cost is literally the least of your worries. Every other element of ownership will cost you more than fuel.
  13. pasadena_commut
    2,436
    730
    Southern California
    Agreed - our car insurance is more than that fuel cost.
  14. 97trophy
    97trophy New Member
    Bought an 05 prius last year & this is exactly right. Any cost saving on fuel for a Prius will be eaten up quickly if you don't DIY.
  15. Moving Right Along
    Moving Right Along Senior Member
    705
    550
    Cars are a lot more expensive than they used to be. With that said, a Gen 4 Prius is likely to last longer than any Hyundai or Kia around the same age. 2nd Gen Prii have also been reliable but are getting old. As an example, I bought my 2009 Prius at the end of 2016 and this year, I'm starting to hit the tail end of the bathtub curve for expenses: maintenance and repair costs have been higher this year than for any other year I've had the car, so I'm looking for a replacement before it gets even more expensive.
    Depending on your budget, a Gen 2 Prius could be a very good deal, as they have been reliable. But even reliable cars can get more problems after they're over 15 years old. I don't think you're going to end up paying less for maintenance and repair of a similarly aged Corolla than you would for a Prius, but I'd set aside $3000 or more per year for overall car expenses. My yearly average has been roughly $3300 for repairs and maintenance, gasoline, insurance, and registration fees.
  16. c.ortiz108
    98
    22
    San Francisco, CA
    That's helpful, thanks. It really does seem to be a matter of paying more up front for a Gen 4, or paying more down the line in repair costs if I buy a Gen 2. Adding in the issue of resale value, it seems like a Gen 4 is the way to go. Your experience with your 2009 is exactly what I'm concerned about. Even great cars age out -- especially without DIY knowledge (or time to learn). I need something relatively hassle-free.
  17. Prodigyplace
    12,458
    11,701
    Central Virginia
    Many people have described ir as a computer on wheels. How is that a mechanically minded person's car compared to a Corolla of the same vintage?
