Front left wheel bearing
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Leroy Smith, Sep 16, 2025.
  1. Leroy Smith
    Leroy Smith New Member
    Georgetown,tx
    I had a rattling noise from the front left side have the lights come on brake light ABS light traction, control, light, and what looks like. The emergency brake light came on when it started having these problems ended up replacing the front left wheel bearing and the lights still don’t go off and when they did it the first time I had a bad grinding noise took it back. They had to redo the front left bearing again everything is fine now but still having issues with all the lights not going off but the lights do go off for for a little while and then they come back on turn back off and then come back on. Does anybody have any ideas thank you
  2. spy1309
    spy1309 Junior Member
    Read the codes and see what they say, it might be something more or one or more ABS sensors might be bad.
  3. Leroy Smith
    Georgetown,tx
    I looked up a scanner to it only doesn’t show any codes so that’s what’s weird about it. Thank you for your response
  4. ChapmanF
    18,566
    That happens often enough when people hook up a scanner that isn't able to show the codes they have.
    When that happens, it's faster to get the codes this way than to spend the time shopping for a better scanner:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    The shopping can be done later, at leisure.
