Hard Knocks- already replaced everything
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Babybird125, Sep 17, 2025.
  1. Babybird125
    Babybird125 New Member
    Nc
    So car was knocking on startup. It has 190k on it so figured we would replace spark plugs. Still bad... replaced injectors... even worse...
    Replaced egr and cleaned out canister... even worse... drained gas and put in new just in case...
    Checked everything I can think of at this point any ideas?
    Codes are for cylender misfires
  2. Tombukt2
    12,924
    2,322
    Head gasket buddy this engine is known for it. Much documentation here
  3. Mendel Leisk
    41,384
    A couple of head gasket links in my signature (on a phone turn it landscape to see signatures).
    Just curious: what do you mean by this, the evaporation charcoal canister?
  4. ASRDogman
    ASRDogman Senior Member
    7,564
    3,903
    And how much is the price of rice in china????
    It is likely you have a damaged head gasket.
    Are you loosing coolant? Have you done a coolant pressure test and use a bore scope to
    looked into the cylinders for coolant leaking between cylinders?
    Most likely between #'s 1 and 2.
  5. rjparker
    10,117
    6,279
    Sorry you spent a lot of money on unnecessary parts. Plugs, coils and injectors don't clear up after a startup. Keep your original parts, in many cases aftermarket parts are worse.
    Symptoms of Prius hg fail
    Losing coolant is not obvious in early stages
    Borescope is the only good hg test in early stages
    Car Care Nut HG Borescope at 660s
    Excellent Borescope Footage at 6:50
    Egr block flow test eliminates egr as a misfire cause
    At about 10:15 in the video he starts talking about the egr valve letting "air" into the intake manifold. He means exhaust gasses.
