OEM spare tire install
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hammersmith, May 31, 2023.
  1. Robmoo
    Robmoo Junior Member
    55
    2024 Prius
    I have to find a way to do this with my LE. The wife is from Minot. We met when I was up there for a year in the Air Force. In what part of North Dakota do you live?
  2. Robmoo
    55
    2024 Prius
    Did you buy new foam pieces? I was thinking that I'd just cut what I have, but it sounds like that won't work well. If you ordered the foam, was it the parts that I see on Hammersmith's list?
  3. Ahimsa9
    Ahimsa9 New Member
    St Louis, MO
    2024 Prius
    Sorry for the delayed response. Yes, I bought the foam that was on Hammersmith's list and it was expensive. I'm not too keen on the fit of the new foam with the old deck board (it "floats" and the foam shows, so I may have to spring $236 to get it through Lewis. Did you purchase the foam and other parts by now?
  4. Ahimsa9
    Ahimsa9 New Member
    St Louis, MO
    2024 Prius
    If you want everything to fit nicely in the back, you may want to reconsider modifying your own foam. My deck height was raised a few inches and I replaced the trim piece at the back of the car to accommodate the taller foam. I would assume the spare wheel/tire would be higher than the stock (cut) foam if you added the carrier to the deck floor.
  5. GcinFl
    GcinFl Junior Member
    43
    2024 Prius
    My Mazda MX-5 had 2 of them. One is for the temporary spare. The other is for the full size to hold it down in the trunk. I took that one to use in the Prius. If my flat full size isn't bolted down in the trunk while I take it to get it fixed or replaced - that's ok.
  6. joejoe12345
    joejoe12345 New Member
    NY
    2024 Prius
    LE AWD-e
    Just want to confirm that this also applies to a 2024 LE AWD as well.
    I didn't see it in the thread or missed it, but since the floor will be 3"+ higher, can you just use the stock foam deck floor (cut out around the spare) and put 3" of foam on top of it?
  7. MScelery
    MScelery Junior Member
    Mississippi
    Before I go and buy all these, since you guys are all awesome and helpful:
    I have a 2025 limited. If I buy the parts in this list:
    1- will it fit for the limited trim?
    2- will everything line up at the same height as folded seats?
    thank you in advance for helping someone who got lost somewhere around page 6.
  8. Hammersmith
    Hammersmith Senior Member
    2,315
    2,354
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yes.
    MScelery likes this.
  9. MScelery
    Mississippi
    And one last question. I have the rubber all weather mat that looks like a square (as opposed to one that fills the entire cargo area). Would that also still work?
  10. Hammersmith
    2,315
    2,354
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yep. The outward appearance on the XLE and LTD doesn't change a bit after the conversion. Same height, shape and dimensions. The only way to know anything has changed is to lift the deckboard and look underneath.
  11. BIDTOYO
    BIDTOYO New Member
    28
    Boise
    2025 Prius
    2026 Prius Limited AWD OEM spare tire/wheel install completed earlier today. Install took about 20 minutes.
    Perfect fit using the listed parts in the original article in this thread.
    Bought the temporary spare tire from Walmart. Paid ~$14 to a local tire store to mount the temporary spare tire on a new OEM wheel.
    The spare wheel rim, three OEM foam parts, metal cover bracket, 3 nuts, and long bolt with cap to secure the complete wheel were ordered with the car from a Houston TX Toyota dealership.
    A new/unused OEM Prius Prime jack kit was purchased from an online used parts supplier.
    This seller was less expensive as compared to purchasing a new jack kit from a Toyota dealership.
    I had a 4-way lug nut wrench and put that in the car as well.
  12. VelvetFoot
    VelvetFoot Active Member
    855
    304
    New York State
    2026 Prius
    While I don't have my LE FWD Prius yet, I've acquired the donut and jack. Since I very rarely use the back seats for passengers, I plan on putting the donut behind one of the front seats. I'd rather not lose the storage space in the hatch are. Plus, there's no additional cost or labor, lol. That's my current thinking anyway.
  13. mingc
    mingc Member
    55
    34
    Portland, OR
    2023 Prius
    XLE AWD-e
    @Hammersmith, do you have more precise measurements for the foam blocks? (I work in both metric and US customary units) Or is 2.0"x2.0"x0.75" and 2.30"x2.30"x1.25" close enough? The photos in post #362 are too angled to get precise measurements. Others, please feel free to chime in.
  14. Ahimsa9
    Ahimsa9 New Member
    St Louis, MO
    2024 Prius
    As far as I know, this conversion works for all Prius models except plug-ins. You should ask Hammersmith for details.
    I wouldn't cut out your original foam to try to make this conversion work. All of the pieces called out here work together as the manufacturer intended (a spare tire kit was included in this vehicle by Toyota in other markets). It's a lot of money to spend, but if you want things to fit and function as intended, you'll need to shell out the dough and buy all of the factory parts to make it happen.
  15. Jamaharon
    Jamaharon New Member
    Mobile, AL
    2025 Prius
    LE FWD full conversion. Parts from post #509 and #511 are PERFECT!
    Mix of IMPEX, Amazon, and local dealer using autoparts.toyota w/ 31% off
    Side note: All Weather Cargo Mat comes with additional pieces for deck flaps and rear seats. Yes! Finally!
    Side note 2: Initial shipping was $51.68 from IMPEX, then they sent message saying additional $619 required.
    Side note 3: Using local dealer instead of IMPEX would have saved $150.
    IMPEX - $234.41 + $671 for DHL Shipping using PayPal, MISTAKE
    $27.29 64997-47100 Box, Deck Floor, LH
    $44.83 64995-47080 Box, Deck Floor, RH
    $44.83 64778-47090 Protector, Spare Wheel
    $62.63 58410-47040-C1 Board Assy, Deck, Spare Tire
    $30.92 64716-47170-C0* Cover, Deck Trim, Rear
    Local Dealer - $376.81 plus Taxes
    $81.06 62112-47240 Wheel, Disc
    $13.49 51931-10040 Carrier, Spare Wheel, RH
    $103.50 PT908-47235-20 All Weather Cargo Liner
    $91.71 09105-47020 Box Set, Jack
    $2.35 42661-47B20 Label, Tire Pressure Information
    $4.59 42668-28090 Compact Spare Tire Caution Label
    $2.63 42668-42010 Compact Spare Tire Caution Label
    $59.80 PT420-00130 Emergency Assistance Kit
    $17.68 81604-WAA01 Triangle Reflector Set
    Amazon
    $98.63 - Kumho T145/90D16 106M 5008233
  16. Hammersmith
    2,315
    2,354
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yep, that's what happened to me, too. It's that stupid deckboard. It's so big it bumps the shipping into a different category(shipping by air is calculated by both weight AND total dimensions). You look at the huge price difference of the deckboard between Impex and a dealership and think there's no way the shipping could make up the difference. And then you get the bill when it's too late to back out and you're stuck. It's why I recommend to not get the deckboard at all unless you really have to and just try to modify the one you already have instead.
    Jamaharon likes this.
  17. Mendel Leisk
    41,643
    Have I got this total right? Or there's some duplication, or omissions? Just trying to understand the expenditure, with shipping, maybe some sales tax omissions.
  18. Hammersmith
    2,315
    2,354
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You've duplicated a bunch. They already subtotaled the different categories.
    The total was:
    Impex - $231.41
    Shipping from Japan - $671.00
    Local dealer - $376.81
    Tire - $96.93
    Total - $1376.15
    The price is so high because of three things. First, they overpaid by ordering the wrong things from Japan and not taking advantage of sales. Second, this was an LE conversion which needs a few extra things. Third, this was an absolutely complete conversion including several items that almost nobody else does(I think it's just this person, me, and one other PriusChat member that have gone this far). I'm talking about stuff like the labels, cargo mat, emergency kit, and triangle reflectors.
    A normal kit for a FWD XLE/LTD should run about a third the amount if you take advantage of the best sales(about $500). Even this exact order with all the extra stuff(including the expensive deckboard - $177.09 in the absolute best case) would only have come to $928.65 if they had ordered it all from one of the 31%-off dealerships next month during the 25%-off Black Friday sale. But they're a Star Trek fan, so we'll let that go. :)
    You have to remember that I started this thread back when none of these parts were available in North America, and I also didn't know about how autoparts.toyota.com worked with the different discounts and sales. Using an importer like Impex was the only option for the handful of us very early adopters back in mid-2023.
    I still use Impex occasionally, but only for things that are only available from Japan or are high value/low weight/size. Most recently(this May), I got the driver kick panel trim with the emergency flare holder(only Japan) and the front side radar sensors(small and very expensive to buy in the US). Shipping for that package was only something like $50, which was much less than the difference in price for even the cheapest place I could have gotten those sensors(including at a junk yard). Those two sensors would have cost me $1221.88 from a regular dealer, $844.76 at a good dealer, and $633.57 from a good dealer during Black Friday. Instead, I paid something like $330 from Impex plus about $50 shipping.
    #538 Hammersmith, Oct 26, 2025
    Mendel Leisk and otatrant like this.
  19. Mendel Leisk
    41,643
    I vacuumed out the hatch this aft (on our 2010), lifted out the tool caddy, checked and topped up the pressure on the spare. Thought of this thread. Yeah, that was then, now is now.
  20. mingc
    mingc Member
    55
    34
    Portland, OR
    2023 Prius
    XLE AWD-e
    I got the whole shebang for my '23 XLE AWD, including stickers, triangle reflector, etc., for $584.00. I did skip the new deck board with the cube foam spacers. All parts were ordered from World Toyota in Atlanta except for the tire.
    Code:
    Box, Deck Floor, Left Hand Part Number: 64997-47100 1 $94.38
    Box, Deck Floor, Right Hand Part Number: 64995-47080 1 $154.09
    Carrier, Spare Wheel, Right Hand Part Number: 51931-10040 1 $13.49
    Protector, Spare Wheel Part Number: 64778-47090 1 $154.09
    Protector, Spare Wheel Carrier Part Number: 51978-47010 1 $35.88
    Disc Wheel Part Number: 42611-21280 1 $78.65
    Box Set, Jack Part Number: 09105-47020 1 $91.71
    Label, Tire Pressure Information Part Number: 42661-47B30 1 $2.35
    Compact Spare Tire Caution Label Part Number: 42668-28090 1 $4.29
    Compact Spare Tire Caution Label Part Number: 42668-42010 1 $2.62
    Flange Nut Part Number: 90178-A0132 3 $3.18
    Triangle Reflector Set Part Number: 81604-WAA01 1 $17.68
    Subtotal  $652.41
    Discount (25% Off, Nationwide Free Shipping)  -$290.59
    Tax $0.00
    Shipping $127.49
    Grand Total $489.31
    I bought the tire, a Yokohama 145/90D16 from Discount Tires, for $94.69, installed. Discount Tires price-matched Walmart's sale price and saved me an out-of-town trip to the nearest Walmart with an auto center.
    I don't remember how I found out but as luck would have it, all Toyota dealers on autoparts.toyota.com that are in the southeast USA were having a 25% off sale when I ordered in September, so I didn't have to wait for Black Friday. (The sale also repeated later for a few days in early October. More recently there was a 20% sale that appears to have been nationwide.) I had never ordered from World Toyota before and wasn't sure how reliable they were. But they sell most things 31% off. They did take a couple of weeks to ship everything but ship everything they did, in one big box. Strangely enough, the wheel did not pulverize everything else in the box.
    I've been wracking my brain wondering how to MacGyver the cube foam blocks on the deck board. I just ordered some expanding packing foam and will try that first. If that doesn't work, I figure I will get a $10 yoga eva foam block from Walmart and cut blocks out of it with a box cutter. I'm not sure though if my hands are steady enough to cut nice square edges. Ideally, I'd like the cubes to look pro and not jerry-rigged.
    Much thanks to @Hammersmith for researching all the part numbers.
    #540 mingc, Oct 28, 2025
