Lost part while trying to reinstall my HV battery.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KnightofNi1, Sep 18, 2025.
  1. KnightofNi1
    KnightofNi1 Junior Member
    United States
    Hi All
    I had a few cells go bad on my 2004 Gen2 HV battery.
    Between some wonderful YouTube vids out there and these amazing boards, it was pretty easy to follow and get them replaced.
    My issue is that I had to take a little bit of time off after replacing the cells and managed to misplace a part in between.
    I am by no means an expert so I have no idea what the part is called but it's essentially a bracket that sits between where the orange cables connect to and the metal case that goes over this section of the battery.
    Does anyone know what that shiny silver bracket is called or have a diagram with the part number on it so I can order one?
    If that's not doable, does anyone know what thin bendy material it's made from? I could probably fashion my own .
    Thanks in advance for any help provided
  2. dolj
    dolj Senior Member
    8,494
    4,313
    Wellington, New Zealand
    It is PNC 82675C - TERMINAL, JUNCTION
    Part number 82675-47080
    KnightofNi1 likes this.
  3. KnightofNi1
    United States
    Thank you so much!
  4. dolj
    dolj Senior Member
    8,494
    4,313
    No Problem.
    FYI, in the second photo above, that part is shown being installed upside down. The two dimples should contact the wire shields, not roll over them.
    This shows the correct orientation.
    #4 dolj, Sep 19, 2025
  5. PriusCamper
    PriusCamper Senior Member
    12,952
    5,264
    Pacific Northwest, USA
    You could probably make one with some thin metal... But I bet you find the one you lost if you remove the backseat bottom. They tend to end up down there when taking a pack apart.
  6. dolj
    dolj Senior Member
    8,494
    4,313
    It's not worth it; they cost less than $3 to buy a new one.
  7. PriusCamper
    12,952
    5,264
    Depends on your location and how much time, money and effort it takes to get that part... And this particular part is likely to make near zero difference if you install the pack without it, but I'll let @ChapmanF refine that.
    And I do have a couple extra and could mail one to OP for free if they send me their address....
  8. dolj
    dolj Senior Member
    8,494
    4,313
    True, but I'm sure the OP can decide whether any of ths is a factor.
    It is an essential component that grounds the cable shielding. Do not leave it off. Also, ensure it is not installed upside down, as this would prevent it from providing the necessary clamping pressure for a proper ground.
  9. PriusCamper
    12,952
    5,264
    While I have no reason to not include it, I bet that if we tested it without it'd be fine. My hunch is that its additional redundancy for pack failures. And I'm not remembering it being used at all on Gen3 Prius? I've not worked on as many Gen3 than Gen2 so not certain. And as always, I trust @ChapmanF 's opinion on this subject.
  10. dolj
    dolj Senior Member
    8,494
    4,313
    Why speculate? Do the testing and report back.
    I'd be interested in your testing methodology. To test effectively, one would need to fully inform themselves about the design and function of the system. However, few people take the time to do this, so it often ends up as just one unqualified opinion against another.
  11. ChapmanF
    18,412
    I think those cable shields are grounded at both ends ... there is also that web of woven shield at the inverter end that connects to the outside of the connector at the inverter and should be grounded through the inverter case.
    So the cable shields probably show as grounded on a meter even if the grounding clamp is missing at the battery end.
    Nonetheless, it's clear Toyota wanted them grounded at both ends. You can find examples in Prius wiring harnesses where they have shielded cable sections variously grounded at both ends or just one end (sometimes between years the engineers change their minds about which end). I had a class where we spent a period on the various engineering reasons for when each of those shielding choices is the right one, but I was, like, 22 then. Long story short, I would make an effort to do it the way Toyota did.
    The shields on those cables play a role in the car's constant monitoring for cable damage, which it does by imposing an extra AC signal on top of the DC carried by those wires, and then trying to detect that AC signal elsewhere in the car.
    PriusCamper likes this.
