Urgent Help Needed - 2007,
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Joey T, Sep 18, 2025.
  1. Joey T
    Joey T Junior Member
    Clarksville,
    I can reset both batteries and the car runs fine for 10 miles or so. Then all dash lights come on, including the triangle, AC stops blowing cold air, and the fan motor located by the passenger rear seat comes on. I had the car 10 years and never heard that rear fan come on. Please help, Thanks.
  2. dolj
    dolj Senior Member
    8,524
    4,326
    Wellington, New Zealand
    You realise that when you "reset the batteries", it only gives the car amnesia until the fault reoccurs, right? It does not fix any fault the car has.
    You need to read the codes (or have the codes read) that correspond to each indicator light and report them here to get advice that will help you.
    #2 dolj, Sep 19, 2025
    Brian1954 likes this.
  3. JC91006
    JC91006 Senior Member
    16,815
    8,596
    Sounds like your inverter pump might have failed
  4. Joey T
    Clarksville,
    Thanks so much for the replies. I replaced the inverter pump about 8 months ago and has run fine until recently. Also, I've had AutoZone check for codes with all lights on, and no lights on. Printout showing no codes either way. Based on their recommendation I've purchased a Toyota Techstream scanner but can't make heads or tails from it being "old, and not tech savvy"
  5. bisco
    52,286
    get an autel maxi 200 scanner.
    ref=sr_1_1_sspa
    was the inverter pump oem? a lot of bad counterfeit chinese junk out there these days.
    you can check for fluid movement in the inverter resevoir.
    might bad a bad hybrid battery, codes will help with diagnosis
  6. Joey T
    Clarksville,
    Ok thanks. The pump was not oem so hopefully that's it. Easy enough fix. Do you know anything about the fan located behind the rear passenger seat? I hear it blowing now and I've never heard that before.
    Thanks for any input you may have.
  7. robodog
    robodog Junior Member
    Tacoma. wa
    Did you ever figure out what's going on with the fan? I had that same issue just start up, it's super loud out of nowhere.
  8. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    Usually, the HV battery cooling fan will turn on full speed when a problem is detected with the HV battery. The red triangle light (master warning) means a problem has been detected with the hybrid system in the car.
    #8 Brian1954, Nov 24, 2025
    robodog likes this.
  9. Rennie
    Rennie Junior Member
    Australia
    Do you also get the petrol engine revving up quite high and the car not accelerating very quickly? When I got the car with bad battery, that's what it did including the battery fan revving and dash lights
