Idea: Low Coolant Sensor to Prevent Head Gasket Failure on Gen 4 Prius
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PatrickL, Sep 19, 2025.
  1. PatrickL
    PatrickL Junior Member
    San Diego
    2018 Prius
    I wanted to float an idea here because I think it addresses a serious problem that a lot of Gen 4 Prius owners are facing.
    As many of you know, when the coolant level drops, the check engine light doesn’t come on until you’re practically empty -- and by then, it’s too late. Within minutes you risk blowing a head gasket. (This is what happened to me). It seems unbelievable that Toyota hasn’t already solved this, but the fact is, there’s no early warning for low coolant.
    My idea is simple: an aftermarket low-coolant level sensor that sits in the reservoir and alerts the driver before things get critical -- say, as soon as the level dips below the midpoint between “Full” and “Low.” A float sensor or probe could trigger a light or buzzer in the cabin.
    The way I see it, this kind of kit could retail for maybe $100–$200. That’s pocket change compared to the $3,000–$5,000 cost of replacing a head gasket or engine. And there are millions of Gen 4 owners out there who might want the peace of mind.
    So here’s my question:
    Would you be interested in a product like this?
    Do you think it’s worth pursuing as a DIY aftermarket kit?
    Considerations:
    Market potential
    Target audience:
    Owners of Prius Gen 4 (millions of units worldwide) plus other Toyotas with similar cooling layouts.
    Aftermarket appeal:
    This could be an add-on kit sold through auto parts chains, Amazon, or Prius enthusiast forums.
    OEM potential:
    Toyota or other automakers might license or adopt it if shown to reduce warranty claims and engine failures.
    Challenges
    Sensor reliability:
    Coolant can be corrosive, and sensors must handle heat and vibration.\
    Calibration:
    It must avoid false alarms (like when coolant sloshes around).
    CARB/EPA considerations:
    If marketed in California, aftermarket add-ons sometimes need regulatory clearance (though a warning sensor is much easier than an emissions-control device).
    That's all I can think of for now...
    I’d love to hear what the PriusChat community thinks. If there’s real interest, I might take the next step and see about getting a prototype made.
    Thanks,
  2. BiomedO1
    3,790
    1,971
    SacTown, Ca
    don't take this the wrong way; but why reinvent the wheel??? There are already existing sensors in the car and all you have to do is monitor the engine coolant temperature.
    If your cheap, why not pop the hood and check your engine oil level and eyeball your fluid levels while your there? I was thought to do that at every fill-up. I'm not one to stop someone from spending money that's burning a hole in their pockets - just so they can avoid popping the hood and doing some basic checks that your owners manual tells you should do.......
    You do You.....
    Doug McC and Brian1954 like this.
  3. Mendel Leisk
    41,643
    Gen 4 coolant dropping is usually due to a defect in the exhaust heat recovery system, defective welds or similar, allowing coolant to leak into the exhaust. Adding a low coolant sensor seems a poor solution, to put it mildly.
  4. Doug McC
    Doug McC Senior Member
    1,079
    418
    Midwest
    2022 Prius
    I agree. Spend money to install a device that could fail (considering the environment it has to operate in) instead of visually checking the coolant level? OKAY, if that’s what you want to do. You’ll still need to pop the hood to check the oil level and brake fluid (unless you want to add more devices that increase the likelihood of failure).
    BiomedO1 likes this.
  5. Mendel Leisk
    41,643
    On the other hand, if a low coolant sensor was designed and implemented at the factory, it could be a good safety-net.
    PatrickL likes this.
  6. BiomedO1
    3,790
    1,971
    SacTown, Ca
    IMHO; They shouldn't have removed the coolant temperature gauge from the instrument cluster. Add to that the ECU doesn't even log an engine over temp incident. That simple adjustment to the software would allow Toyota to say - "look at how may times you ran it hot." and your surprised the engine or head gasket blew?????
    Getting off the soap-box now......
  7. BiomedO1
    3,790
    1,971
    SacTown, Ca
    I think they actually want to be driving a BMW or MBZ; no dip sticks. Just a $ icon in the dashboard which indicated "take me to the dealership" and I hope your credit card isn't maxed out.o_O:D:LOL::ROFLMAO::eek::whistle:
    Doug McC likes this.
  8. bisco
    52,093
    i think it's brilliant. the coolant light comes on after the head gasket blows.
    if i had an early gen4 with the original heat exchanger, i would absolutely buy one.
  9. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    Okay, I'll take a shot at this:
    Specification: A gadget that makes it easy and convenient to discover coolant loss before it becomes critical. Needs to be easy to operate and easy to install. Should be inexpensive and easy to understand. Needs to accurately show coolant levels- false readings are not acceptable.
    Suggestion:
    Get one of these tiny cameras with a magnetic mount, and install it under the hood pointed at the coolant reservoir.
    Can't be that hard to supply power to it. Not sure how well it would handle underhood temps, but for $34 it's probably cheaper than any other sensor or doodad you could put in there. And you get a picture of the coolant level whenever you care to open the app and look, from the comfort of the drivers' seat.
    I think a live monitor of engine coolant temp is probably even better, but if you positively want to monitor actual coolant level I can't think of anything cheaper, easier and more likely to be reliable than this.
    Tande and BiomedO1 like this.
  10. bisco
    52,093
    would it need light?
  11. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    Unknown, somebody would have to guinea-pig it and find out. Some of those gizmos have night vision, some don't. Worst case, it wouldn't be much harder to add a small light source on the opposite side of the reservoir and feed it and the camera a common power supply from the fuse panel.
  12. BiomedO1
    3,790
    1,971
    SacTown, Ca
    LoL; I can't tell if your serious or joking. If money was no object; pay some kid to do it on a weekly basis. Probably the kid who mows your lawn. I'm probably dating myself, since genZ is too lazy to even do that. The lawn mower fumes or the blade may fall off and hurt my poor baby.:(:cool:o_O:rolleyes::ROFLMAO:
  13. BiomedO1
    3,790
    1,971
    SacTown, Ca
    I've seen those fairy lights for only a dollar.:eek::D:LOL::ROFLMAO::sleep::whistle:
    OOhh; I heard that if you touch that hood release button - you can get cooties!!!!!
    #13 BiomedO1, Sep 20, 2025
  14. bisco
    52,093
    idk if a weekly check would be often enough or not. not sure how quickly it can drain when the exchanger starts leaking.
  15. BiomedO1
    3,790
    1,971
    SacTown, Ca
    It's close enough for government work; If it was dumping out quickly there would be white smoke out the tail pipe followed by the temperature icon on the dash - perhaps no heat when using the heater.;)
  16. rjparker
    10,238
    6,393
    A coolant reservoir monitor would have to deal with coolant flow entering from the upper reservoir hose. Even if the reservoir was 2" low realtime monitoring would be tricky. Perhaps a led transmitter, a receiver on the opposite side, both outside the reservoir and some elaborate controller that could filter out false negatives. Perhaps the controller only looks at static levels at startup. Since we need to add a controller, might as well add coolant temperature and include an audible alarm and readout for the driver.
    Maybe that is too much of an science fair project with little chance of commercialization. How about a root cause solution that prevents coolant from being lost?
    Preemptively change the entire assembly. Effective but costly.
    or
    Bypass the exhaust heat exchanger and move on with your life. Parts cost? Zero to $10 depending where you do it.
  17. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    The heat exchanger leaks aren’t gushers, for crying out loud!
  18. rjparker
    10,238
    6,393
    Under pressure I am sure you could lose the small amount in the reservoir in one drive.
    The exhaust heat exchanger has flow at all times in Ready as it discharges to the thermostat bypass inlet. The reservoir tank does not flow until the thermostat opens, usually within 5 minutes of a cold start.
  19. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    Honestly somewhere in between.
    I think popping the hood and looking at it a couple times a month is easy. I think the same $35 would get you most if not all of a simple OBD-attached realtime temp gauge.
    But if somebody really wanted to go for it? Why not? It would be cheaper than an actual level sensor, and probably more accurate because it allows the operator to use their vision and reasoning as the false-reading-preventer.
    ...and after putting it in and using it a few times, they might decide that popping the hood really wasn't that hard.
    BiomedO1 and Doug McC like this.
  20. PatrickL
    San Diego
    2018 Prius
    Well, I blew a headgasket when the coolant dropped to a level so low it was too late causing overheating, the check engine light went on, but no where near soon enough. Sure, I could have done better, but not everyone knows these things, I find out the hard way too late. I'm just saying, the car has sensors, but not for coolant levels. I think it would be good idea.
    Wouldn't it be too dark with the hood closed? I you suggesting a permanent lighting solution?
    #20 PatrickL, Sep 21, 2025
