Anyone know the part number for Midnight Black Metallic touch up paint?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by MScelery, Sep 19, 2025.
  1. MScelery
    MScelery Junior Member
    83
    24
    Mississippi
    I’ve looked and looked, but I keep seeing cross references with “attitude black” whenever I use the part # on the Toyota website, which doesn’t seem to be the same color.
    I’d like to order the base paint, touch up paint, and clear coat for my car to have on hand as needed, but I’m having no real success knowing the right “part” # or code or whatever I need.
    for reference, this (Touch up Paint - Midnight Black Metallic) is what I found on Toyota, and the listing says “midnight black metallic” but even the actual URL of the linked page says “attitude black”…
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Attitude Black and Midnight Black Metallic are the same color.
    Toyota will often rename colors in different markets to make them sound "better". But the parts system almost always uses the original Japanese name for the color(translated). In any case, your color code is 218.
    Code:
    Code   North American Name          Japanese Name
    040    <not available>              Super White II
    089    Wind Chill Pearl             Platinum White Pearl Mica
    1L0    Cutting Edge Silver          Silver Metallic
    1M2    Guardian Gray                Ash
    218    Midnight Black Metallic      Attitude Black Mica
    5C5    Maximum Yellow/Karashi       Mustard
    3U5    Supersonic Red               Emotional Red II
    8Q4    Reservoir Blue               Dark Blue
    PrimeDan, PhoS and MScelery like this.
  3. Mendel Leisk
    41,826
    Could be on your VIN decal. We're Classic Silver Metallic, and the paint code is 1F7:
  4. MScelery
    83
    24
    Mississippi
    Thanks. That’s where I started, but like I said on the previous post, it appears Toyota markets it as attitude black, which I’ve now learned is the same thing as midnight black metallic. The more you know…
    Thanks!
    PrimeDan likes this.
  5. aaronjy
    aaronjy New Member
    2025 Prius
    One thing to note: I accidentally bought just the clear coat and glitter coat, but not the base coat. On the pens, the base coat will be 218-BC and the glitter coat will be just 218. Very confusing in my honest opinion, as nothing on the Toyota website implies 218 is a glitter coat (the name is literally titled the same as the base coat), and there's nothing in the door jamb that says anything about base coat and glitter coat being separate, either.
    otatrant and MScelery like this.
  6. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Good to know. Looks like it's just black and white that have a separate base coat. Silver, gray, red, yellow, and blue are all single pens.
    otatrant likes this.
