Trying to use a portable CD player - Any Bluetooth transmitter that will pair, or other CD solution?
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by mowgli, Oct 15, 2024.
  1. mowgli
    mowgli New Member
    Massachusetts
    2024 Prius Prime
    XSE Premium
    I have a 2024 Prius Prime, I of course wasn't expecting it to come with a CD player but not a problem, I have a portable CD player with a cigarette lighter adapter. Problem is, I wasn't expecting there to be no aux input in this car! So I bought a cheap Bluetooth transmitter off Amazon, but the car doesn't see it at all when I try to pair. I'm not sure if it's the transmitter or the car that's causing problems, but before I waste money on a different transmitter, could anyone recommend one that will work, or any other simple solution they've found for playing CDs? I suppose I could get an FM transmitter in the worst case scenario but I'd rather not take the hit in audio quality
  2. mowgli
    mowgli New Member
    Massachusetts
    2024 Prius Prime
    XSE Premium
    Well I took a chance on a different Bluetooth transmitter that specifically advertises itself as suitable for rental cars, and it works great! For anyone else who comes across this thread looking for this information, the product is AirFly SE, bought for about $35 at Walmart plus a $4 USB-C cable to keep it charged in the car
  3. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    Thanks for this post. Do you mind sharing how this system is working for you? Do you have a recommendation for a good portable CD player? Needs to be Bluetooth compatible, right? Anything else I might need? Can’t imagine not having access to a CD player in my car.
  4. Mendel Leisk
    41,329
    Geez I was going to suggest that. That’s the ONLY method on our ‘10, for playing music off a phone.
    I appreciate mediums come and go, but thankful ours has the built/in 6 cd player.
    #4 Mendel Leisk, Dec 10, 2024
  5. mowgli
    mowgli New Member
    Massachusetts
    2024 Prius Prime
    XSE Premium
    Nope, the CD player doesn't need Bluetooth, the AirFly just plugs straight into the headphone port on the CD player and transmits that signal over Bluetooth to the car
    The CD player I'm using is this one, iLive brand, only reason I bought it is because they sell it in store at Best Buy (my local one anyways) and it's cheap ($25) The reviews on it have some complaints about it having trouble reading CDs or just flat out not working, but I haven't had any issues, but keep that in mind. Only annoyance is the volume resets every time you turn it on or switch discs (but even at max volume you're gonna have to crank up the volume in the car anyways) It runs on batteries but I bought this car adapter from Amazon which plugs into the cigarette lighter. It can be a bit of a pain to change discs while driving, all I'll say is Lane Trace Assist will let you take your hands off the wheel for a few seconds before it complains ;) If I was trying to invest in a higher quality CD player I'd probably look for a used Sony Discman (they've been discontinued and I don't know of any other big brands that still make portable CD players)
    daisy555 likes this.
  6. daisy555
    1,715
    708
    CT
    Thanks for the details. I spent some time searching more options and found a few other players with mixed reviews. Someone pointed out one that actually connects to CarPlay but it’s more than I want to spend (includes a DVD player).
    Important for me is finding one that has memory feature for where I stopped within the audio book.
    #6 daisy555, Dec 11, 2024
  7. VelvetFoot
    VelvetFoot Active Member
    534
    172
    New York State
    2026 Prius
    I used this thing in my MINI (don't have the Prius yet).
    It plugs into a USB port.
    Controlled by the steering wheel buttons.
    Worked well.
    Got it off Amazon, I believe.
  8. bisco
    51,843
    #8 bisco, Sep 20, 2025
  9. VelvetFoot
    534
    172
    New York State
    2026 Prius
  10. bisco
    51,843
    i want to get one for our hycam, i miss audio books
  11. otatrant
    otatrant Active Member
    321
    196
    San Francisco
    2023 Prius Prime
    XSE Premium
    Why not rip the music of the cd and put in on a usb-c thumb drive which you can than plug into the media system?
    mingc likes this.
  12. bisco
    51,843
    for me, i'd have to buy the equipment
  13. VelvetFoot
    534
    172
    New York State
    2026 Prius
    In my MINI I put it in the glove box.
    I listen to mostly FM and XM.
  14. bisco
    51,843
    on amazon, there are at least 3 that look exactly the same, but different prices. the good thing is, you can return it if it doesn't work.
  15. VelvetFoot
    534
    172
    New York State
    2026 Prius
    You have to figure out where to put it.
    edit: There are a few usb-c ports, I think, right?
  16. bisco
    51,843
    idk what the gen5 prius has. on our '24 hycam, the only usb that feeds the audio is in the center console
  17. Leadfoot J. McCoalroller
    8,071
    7,552
    Pennsylvania
    2018 Prius c
    It's barely $50 for a portable CD player with bluetooth built into it. Uses USB for power. Seems like an obvious solution.
  18. otatrant
    321
    196
    San Francisco
    2023 Prius Prime
    XSE Premium
    $14-$27 for one Samsung usb-c thumb drive that can store the music from 90-360 compact discs.
    Yes and only the one on the left side of the instrument panel can act as an aux port or host a usb-c thumb drive to play music.
    VelvetFoot likes this.
  19. Paul Gregory
    Paul Gregory Senior Member
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    I think the Bluetooth system of the car is expecting to pair with a phone. I don't believe it's made to pair to a CD player. If you're lucky, you may be able to play it through an FM transmitter.
    Another option may be to upgrade to a stereo which has a CD player built in, although they are becoming quite rare. I can't recommend one with a built in CD player, but it shouldn't be hard to find one with an aux input.
  20. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
