Steering wheel cover
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Keith Kerns, Sep 4, 2025.
  1. Keith Kerns
    Keith Kerns New Member
    Jacksonville
    XSE
    Hi Everyone. I just bought my first Toyota Prius. 2024 Prime XSE. I got a leather steering wheel cover that I’d slightly too big. Does anyone have a suggestion on altering to make fit or a suggestion on the best one to get for perfect fit? Thanks
  2. VelvetFoot
    VelvetFoot Junior Member
    Wednesday
    33
    New York State
    2025 Prius
    I'm waiting on mine.
    Just recently I tried putting on a sew-up leather cover on a Crosstrek. Couldn't make it work, I felt, with all the smart features of the the steering wheel.
    I had a 2000 VW beetle that I put a sew up one on and it was great.
    For the Crosstrek, wound up getting a slip on 'leather' cover, ie, no sewing. She likes it.
    You have to get the right size. Maybe you can exchange it? They're not that expensive.
  3. xliderider
    xliderider Senior Member
    8,130
    3,268
    Honolulu, HI
    +1 to getting the right size, this cover from Amazon was thin enough at the edges to tuck under the plastic bits of our 2025 Toyota Crown Signia steering wheel. FYI, the cover comes with thread to sew the cover on, but I don't use it because it is made of a slick synthetic material. I get a waxed thread that is thicker and easier to use.
    https://a.co/d/5F5MH1U
    The Signia has a factory real leather steering wheel already, but we prefer a nice, thick steering wheel.
    https://a.co/d/bSMWZ1J 20250304_233633.jpg 20250304_233724.jpg
    VelvetFoot likes this.
  4. VelvetFoot
    Wednesday
    33
    New York State
    2025 Prius
  5. Humble Bear
    Humble Bear Member
    127
    47
    Arcadia, CA
    2024 Prius
    That was a marvelous steering wheel job you did. Was that a custom-made steering wheel cover because I see that there were bulging areas at 2 & 10 o'clock position and then the cover conforms to the bottom spoke?
  6. xliderider
    8,130
    3,268
    Honolulu, HI
    Nope, off-the-shelf cover, linked in previous post.
    The bulged areas at 10 and 2 aren't completely covered, there's a slight gap between the edges.
    As far as the bottom of the wheel, the cover is tucked under the plastic trim with a spatula type trim tool. The cover is tied off directly adjacent to the bottom spoke, then the lacing continues on around the steering wheel.
  7. VelvetFoot
    Wednesday
    33
    New York State
    2025 Prius
    I might give it a try when I get the car!
    Too bad it's not heated, but you don't have that problem where you are, lol.
