Would This Car Jack Do The Job?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Sep 21, 2025.
  1. VelvetFoot
    VelvetFoot Member
    243
    59
    New York State
    2026 Prius
    (I don't have my Prius yet. This forum is helping me cope with the wait.)
    This jack seems to accommodate a "pinch weld", which I've read of.
    Would this jack work?
    Or, I could put the HF 2.5 ton hydraulic jack back there-it weighs less than 20 lbs.
    I had that jack and a 24" HF breaker bar in my MINI. Would have to modify a hockey puck or use an adapter on this jack, I suppose, to deal with the pinch weld.
    Scissor Jack - 1-1/2 Ton
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,411
    2,387
    Taylors, SC
    That jack is not appropriate for the Gen 5 Prius.
    You need a jack with a flat top with a 3/4 inch deep slot in the middle.
    #2 Georgina Rudkus, Sep 21, 2025
  3. VelvetFoot
    VelvetFoot Member
    243
    59
    New York State
    2026 Prius
    Thanks.
    I've had issues in my past with pinch welds getting bent over (VW), either by me or a tire shop.
    So, it pays to get something with the right support.
    The MINIs (BMW) I've had have rectangular platforms, which seem better.
    They have plastic stuff nearby that has to be dealt with, I suppose.
  4. BiomedO1
    3,222
    1,706
    SacTown, Ca
    your tire shop got lazy and didn't use the pinch wield blocks with their jacks.
  5. VelvetFoot
    VelvetFoot Member
    243
    59
    New York State
    2026 Prius
    Last I paid attention, they use something that spreads the load.
  6. Mendel Leisk
    41,049
  7. VelvetFoot
    VelvetFoot Member
    243
    59
    New York State
    2026 Prius
    I ordered that jack he specified.
    As I said in another thread, might still carry the 24" breaker bar as an alternative to the tiny lug wrench provided.
  8. ETC(SS)
    7,087
    I have 4.
    One for and IN each vehicle.
    I also have the appropriate 1/2" deep socket pre-attached.
    Harbor Freight!
    Gotta love it!! :)
    Winston Smith and VelvetFoot like this.
  9. VelvetFoot
    VelvetFoot Member
    243
    59
    New York State
    2026 Prius
    I've had to stomp on those little guys in the past.
  10. Mendel Leisk
    41,049
    I wouldn’t describe it as tiny. It’s effective, unless the lug nuts were installed by a gorilla with an impact. then you might need a section of steel tube to slip onto the wrench handle, to increase leverage.
    A square of 3/4” plywood (say 8” sq) is good too, in case you’re placing scissor jack on soft earth. A couple of wheel chocks are good too, for the wheel diagonally opposite the flat.
    At least on the gen 3, the scissor jack does not even touch the “pinch weld”; it cups around it, and the flat tops of the jack contact the flat car body, mostly if not all on the inboard side, and even with a single use leave dimples. Unlike previous Hondas we’ve had, the pinch welds seem to have no reinforcement at the specd jacking points.
    FWIW I’ve read here that may have been rectified with gen 5.
    also, other than being compatible, the Toyota jack is no great shakes. The cast iron eyelet that the torque rod eyelet hooks into is garbage steel, and being single eyelet it dances around as you crank it up. Honda jacks are superior in that regard, use a u-shaped bent plate with two holes, much more stable.
    Gotta say, all of this should be provided by Toyota.
    GcinFl likes this.
  11. VelvetFoot
    VelvetFoot Member
    243
    59
    New York State
    2026 Prius
    Key
    Re: cheater bar. My goto tire place doesn't go crazy with the impact wrench. I've had places in the past that did. I usually made sure they were to spec when I got home, but laziness...
    The piece of wood is a good idea. Perhaps it could be incorporated in the spare tire platform setup, lol.
  12. Georgina Rudkus
    3,411
    2,387
    Taylors, SC
    Any used Mazda scissors jack will also work.
    GcinFl likes this.
  13. VelvetFoot
    VelvetFoot Member
    243
    59
    New York State
    2026 Prius
    Good to know, but too late at this point, lol.
    Probably not a totally bad idea to buy an item of this type new.
  14. Blackat
    Blackat Active Member
    437
    298
    Colorado
    2023 Prius
    Limited AWD-e
    Try it and see if it works
  15. VelvetFoot
    VelvetFoot Member
    243
    59
    New York State
    2026 Prius
  16. Hammersmith
    Hammersmith Senior Member
    2,218
    2,225
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    FYI, the gen5 jack is not a pinch weld style; it's a (mostly)flat top. What Toyota has done with the gen5 is incorporate thicker pieces of steel at the four jack points. These pieces are sandwiched into the pinch weld and the bottom edge is rolled over to provide a place for a flat topped jack to sit. It's not a large amount of flat space, but Toyota must consider it enough to do the job.
    Georgina and I disagree on the jack. They say Toyota must be mistaken on the part number they give for the gen5. I say Toyota's had almost three years to correct any mistake and even the image shown on the parts diagram shows the flatter style jack. We've just agreed to disagree.
    Since you used the part number in my thread(the official part number), you're going to receive the mostly flat top jack that's in my pictures in that thread.
    VelvetFoot likes this.
  17. Mendel Leisk
    41,049
    Good to hear!
    Our 2010's proscribed scissor jack points don't appear to have ANY reinforcement, on either the crimped seam or the adjacent sheet metal. I needed to use the supplied scissor jack once, on a rear corner, and it left the sheet metal just inside of the crimped seam dimpled in slightly, and that's the lighter end of the car.
