2013 Prius C "check hybrid system"
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Memphis_Sean, Sep 22, 2025.
  1. Memphis_Sean
    Memphis_Sean New Member
    Memphis
    No issues with the car until after it sat for several months. I just replaced the 12v battery and received the "check hybrid battery" message/car didn't start. What things can I check myself prior to taking it to the dealer?
  2. Brian1954
    Brian1954 Senior Member
    2,161
    839
    South Central PA, USA
    Purchase and use an OBD2 scanner to read the trouble codes. Take a look at this thread, Gen2 OBD2 app review | PriusChat
    Read post #1 and then scroll down to post #37. You want to buy a scanner that can communicate with all the ECUs in the car. I recommend the Autel AP200 scanner. It is an OBD2 Bluetooth dongle, and you install an Autel app on your phone. The Autel AP200 costs about $60 on Amazon.
  3. Leadfoot J. McCoalroller
    8,071
    7,553
    Pennsylvania
    2018 Prius c
    yeah you won't get far until somebody does a proper scan of the on-board diagnostics. The thread linked above has lots of great info.
    That Autel is a very good unit, gives you access to all the same stuff the dealer can tell you except you own it forever at about 1/3 the price of a single dealer diagnostic visit.
    Good luck!
    Memphis_Sean and Brian1954 like this.
  4. Memphis_Sean
    Memphis
    Unfortunantlly as the car sat the 12v battery went dead and there are no saved codes...
  5. Memphis_Sean
    Memphis
    I have a Bluetooth OBD Reader coming later today...so I'm going to give the Dr.Prius App a try
  6. Leadfoot J. McCoalroller
    8,071
    7,553
    Pennsylvania
    2018 Prius c
    That's better than nothing, but that app can't do a comprehensive scan of a Prius.
    Good luck!
  7. Memphis_Sean
    Memphis
    Car has the P0A0D code, so I narrowed it down to possiblly having a bad safety/service plug...
  8. Memphis_Sean
    Memphis
    Can you recommend a good Autel or other brand hand held scanner?
  9. Brian1954
    2,161
    839
    Remove the orange safety interlock plug and reinstall it per the directions below.
    There are three steps to install the orange safely plug.
    1. Insert the plug into the socket.
    2. Flip the lever of the plug.
    3. Slide the lever. This last step is something not completed, which will cause the code.
    Here is a diagram from a Gen 2 Prius.
    Memphis_Sean likes this.
  10. ChapmanF
    18,086
    If that doesn't sort it, you can take that plug out again and examine it closely. You can look at what happens when that handle lever is slid sideways in the last step: a jumper connects two small pins that stick out at the side of the socket, completing the safety interlock circuit. Make sure those pins aren't bent, and they mate cleanly with that handle.
  11. Leadfoot J. McCoalroller
    8,071
    7,553
    Pennsylvania
    2018 Prius c
    I can't, honestly. The AP200 and AP2500 smartphone-based ones work very well and they're quite inexpensive.
    I know Autel does make some dedicated handheld devices which may have the same advanced diagnostic capabilities, but they cost so much more that most of us DIY types have focused on the smartphone-based ones instead.
    I've noticed that Autel themselves have been gradually phasing out their handheld hardware in favor of a ruggedized Android tablet paired with a bluetooth dongle. From my point of view, you can save a fortune by getting the AP200 and using your own cheap tablet instead.
    Good luck!
  12. Memphis_Sean
    Memphis
    Switch visually looked fine but parts guy said they are a maintenance item and go bad hope this is my issue
  13. Memphis_Sean
    Memphis
    Autel sells several models of handheld from less then $40 to like $500 on Amazon...I just didn't want to have to have a blutoothth/wifi connection...just plug in and go to work, but I agree prob cheaper...
  14. ChapmanF
    18,086
    Hmmmmmmmmmm.
    I think I would look a little extra first. The P0A0D code is about a safety interlock circuit that is very simple, a series circuit that starts at an ECU and goes through some cover switches at the inverter and through the small contacts in the battery service plug and ultimately to ground (when all the covers and the plug are properly in place). Doesn't take anything more than rudimentary poking around with a multimeter to find out where the circuit is open. If that's at the service plug, it should be easy to see why. Or it could turn out to be someplace else.
  15. Memphis_Sean
    Memphis
    I didn't mention I brieflly spoke to a tech and after explaining the code etc was the first one to recommend replacing the switch and then going from there...it was only $30 but had to order it...not sure how easy it would be to find a break...
  16. ChapmanF
    18,086
    I'll withhold comment then until the switch is replaced and we see what that does.
  17. Memphis_Sean
    Memphis
    Scheduled to be delivered on Sa
    Scheduled to be delivered on Sat lol
  18. Memphis_Sean
    Memphis
    What do you think it is?
  19. ChapmanF
    18,086
    I don't really have a prediction. If it were my car, I'd just break out the multimeter and divide/conquer that simple circuit till I found the spot where there was continuity to ground on this side and not on that side, and then say "oh" and fix it.
    I'm not saying the other guy's wrong about the service plug connection being a wear item, just that it sounds dubious to me.
  20. Memphis_Sean
    Memphis
    Update: go figure once I put the new plug in the error code went away and the car seems to be running normally
