2017 Toyota prius sounds like a wobble behind it.
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Umutcan, Sep 18, 2025.
  1. Umutcan
    Umutcan New Member
    Hello everyone, I have a 2017 Toyota Prius three car, and now there is a wobble sound on the highway at 87000 miles and this started to increase. When I look at the back of my vehicle, I see that there are resources in the suspension system, can you give me any advice?
  2. Allen.z
    Allen.z New Member
    Hong Kong
    Given the mileage and symptoms, a worn shock absorber is a top suspect. Have this checked first. A "wobble" often points to a worn damper (shock absorber) that is no longer controlling the spring's movement properly, leading to an oscillating or bouncing sensation. If shocks are leaking or bushings are cracked, replacement is necessary.
  3. bisco
    51,901
  4. BiomedO1
    3,585
    1,856
    SacTown, Ca
    I'm not sure what a "wobble sound" sounds like and I don't know what "resources in the suspension system" means? We can all guess at what your trying to allude to. There's plenty of parts to pick from in your rear suspension system - but you'll need to be a bit more specific in your problem description.
    You should probably take it to a professional because it seems that your a bit out of your depth here.
    Was this an AI generated problem description???????
    #4 BiomedO1, Sep 22, 2025
  5. bisco
    51,901
    my guess: resources = rust sources?
  6. Mendel Leisk
    41,425
    This bolt in particular (from second of OP’s pictures) is evidently adjustable:
    That said, barring a curb bump or similar, I don’t think they just slip out of optimum alignment, more likely something rubber, bushing or tire as mentioned.
