New owner 2026 Prius PHEV
Discussion in 'Gen 5 Prius Main Forum' started by Eguyprius, Sep 22, 2025 at 12:39 PM.
  1. Eguyprius
    Eguyprius New Member
    Toronto
    2025 Prius Plug-in
    Hi....I didn't see an intro thread...so I hope I'm posting in the correct area. Admin: please move if I've made a mistake.
    I've spent a few hours reading posts on the forum, and there's some great info. here. Some contrasting views, too, so I thought I'd try a direct approach to my queries...
    *My previous vehicles were 2 Civics, a Corolla, and a Cruze, (-not in that order). This Prius is by far the nicest car I've ever owned, (top trim level, too), and the most complicated; my head is spinning.
    1. I live in a northern climate. I'd like to warm up the engine before driving in the winter. If the car is started remotely, and the outside temperature is low, will the gas motor automatically start up? Should I buy a block heater? I know that if I sit in the car and hold the brake and tap the gas pedal in HV mode, the motor will start up.
    2. My previous car, a 2019 Civic, had cloth seats and a mostly plastic interior, so I only wiped the interior down with a damp microfiber cloth as necessary. The Prius has soft-tex seats, a leather steering wheel, etc., and I'd like to keep these surfaces in good shape. Does ArmourAll cut it on the soft-touch materials? Should I use leather conditioner on the seats and steering wheel? Brand/product recommendations appreciated.
    3. Is there a brand of extension cord that you'd recommend, something that would protect the external connection to the charger from rain/snow? I believe I read that a shorter-length 10 gauge cord would be better/safer (?)
    4. Driving: when I don't use my turn signal, the car will actively steer against me. This has caught me off guard a couple of times, hehe. Sometimes I don't want to signal when approaching an intersection where I'm turning right and there's a driveway. *There can be a driveway and a car wanting to pull out which mistakenly thinks I'm turning into the driveway, (-of say a gas station). Typically I use the signal after passing the driveway, but the car doesn't like that. Is there a way to disable this? I've watched numerous videos and can't seem to find what I'm looking for. The owner's manual is a monster, and is not intuitively written, IMO. It's a real chore to dig though. *I've already disengaged the eye-follower function, as the car always felt I wasn't looking at the road...
    Thanks for any advice. Here's what I've learned from the forum and done to the car so far:
    -I learned not to charge the battery to 100 percent, (-to maintain the battery for the long haul), unless I drive a bit the next day,
    -an extension cord can be used if necessary,
    -the headliner material is very delicate,
    -ammonia free glass cleaner is recommended,
    -electric only mode is ideal for city-driving, HV mode is best for highway driving,
    -hybrids are tough on their gasoline engines and should be warmed up a bit before heading on the highway,
    -I've had PPF film applied to the full front, (hood, lights, plastic bumper), A pillars, hatch and door sills, all fenders
    -I've had the metal parts under the car treated with 'corrosion free' anti-rust formula, (EV safe and non-dripping)
    -I've had a 5 year ceramic coating applied, (glass and wheels, too). I plan on keeping this car as long as I can.
    -I've installed interior screen protectors for the infotainment system, and dash
    -I bought the Toyota trunk liner
    -I bought expansive seat mats that protect the carpeting, (-Tuxmat)
    -I bought an amazon tray that installs in the main cubbyhole beside the driver
  2. Eguyprius
    Toronto
    2025 Prius Plug-in
  3. john1701a
    john1701a Prius Guru
    12,803
    5,287
    57
    Why? I live in Minnesota and have done countless winter commutes without consuming a drop of gas. Here's one I recorded doing exactly that...
    Eguyprius likes this.
  4. PriusCamper
    PriusCamper Senior Member
    12,333
    5,008
    Pacific Northwest, USA
    Yep... The whole notion that hybrid engines are somehow problematic because of all the starting and stopping it does is bogus fossil fool industry propaganda based on non-hybrid car engine data. The truth is you get double the lifespan of a hybrid car engine (not counting Gen3 Prius) because it gets used less often. And if you have a plugin Prius and drive in EV mode around town most of the time you're going to get way, way, way more than double the lifespan.
    All that being said, if you're interested in doing everything you can do to take care of your car, as well as boost MPG, get an engine block heater and plug it in the night before, or put it on a timer to turn it on while you sleep before days you know you're going to be needing to use the engine in cold weather.
  5. Eguyprius
    Toronto
    2025 Prius Plug-in
    I'm a motorcycle guy....I guess I've always been under the impression that its best to warm up the gas motor before use. And I thought the hybrid's gas motor was necessary to warm up the cabin in cold weather (?)
    For my work commute the EV range is great, actually. On the weekends I tend to travel beyond the EV range, though.
    *Also, my neighbor has a previous gen. Prius Plug-In in, and he warned me not to jump on the highway without giving the gasoline motor a chance to warm up. We live close to a major highway, but as it's a toll route, I tend to use city streets for my work commute.
  6. Eguyprius
    Toronto
    2025 Prius Plug-in
    I'm probably overdoing/overthinking things. I'm still learning how the car behaves and likes to be driven. If the car starts it's journeys in EV mode, (which is almost always as i charge overnight), and doesn't need the gasoline motor to run the heat in the cabin initially, then maybe I can get away without a block heater...
  7. bisco
    51,518
    congrats and welcome!
    she's gorgeous, all the best!
  8. Zeromus
    Zeromus Active Member
    530
    292
    Ottawa Canada
    2024 Prius Prime
    SE
    Toronto isn't that cold, but when its cold enough, the engine will run instead of EV mode, and it will warm up the cabin and the battery heating elements will get it to a good temp to let the car drive like the non plugin model. anything thats below -12C turns the car into the non-plugin prius. For us in Ottawa, between December and March is when we use most of the gas in our car, probably 2/3s of our fuel is used in those 4 months. But the rest of the year, it's mostly EV mode since we can do all our daily driving in the non-winter EV range. In the worst of the winter range we can almost cover our daily driving with EV range when its above -12C. It's really just when it gets too cold that we use gas most of the time. And for the first year with the 2024 model, without road trips and daily driving only, we used maybe 3 full tanks of gas?
    So I wouldn't worry too much.
    Eguyprius, GcinFl and mva like this.
  9. PriusCamper
    12,333
    5,008
    Seems like a heating pad for the battery pack would be great mod for Gen5... I'm suprised Toyota didn't realize the value of that?
  10. Eguyprius
    Toronto
    2025 Prius Plug-in
    This was exactly the information I was looking for. Thank-you thank-you. :) :) :)
