MFD Touch alignment calibration
Discussion in 'Gen 2 Prius Main Forum' started by november, Oct 25, 2009.
  1. november
    november New Member
    ut
    Hi there, I have an '04 Prius w/ a nav system. The LCD seems to be working fine and does not have the usual "a/c not connected" or complete failure issues, but its touch inputs are misaligned.
    For example, when I want to to hit a button I have to touch to the left of the button that I want to activate. Also the problem is worse on the left side of the screen, i.e the further left the desired button is on the screen the further left the "windage" adjustment must be. So basically the far right side of the screen is fine but the left side is way off.
    Does anyone know of a hidden menu to calibrate the touchscreen? I have seen these on other devices, and you hit a target placed in various points on the LCD to align the touches to the screen. I have found a menu that is sort of a diagnosis for this problem, it just confirms the problem that I have but does not fix it. It shows a target that moves to where I touch but does not remedy the misalignment.
    Thank you.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    The moving target is supposed to fix the alignment. I know of no other way to adjust it.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Bump.
    Am having the same problem in a '06 Prius w/Nav.
    Where do I locate the "moving target" to perform a screen calibration? Thanks.
  4. hill
    8,910
    Here's access for the diagnostic menu and MFD alignment. I think what you're looking for show us at the 1 minute mark:
    I've never had to mess with changing ours.
    wjtracy likes this.
  5. The Critic
    3,193
    2,333
    CA
  6. youdiejoe
    youdiejoe Member
    31
    48
    Los Angeles
    I was having trouble with my 2007 MFD touch screen, it was WAY out of alignment, mis-reading my touches on screen by several inches.
    I use to have an old Compaq PDA that had a calibration function and figured that one had to exist for the Prius MFD, luckily a google search lead me to this link:
    2007 Prius - Easter Egg
    Which gives you instructions on how to reach the "Diagnostic Menu" which many people have posted about. This 1st level menu has a "Display Check" but no actual calibration functions. LUCKILY there is 2nd level menu you can then reach called "Product Diagnosis Menu" (step by step instructions on how to access this menu are at the link above) and it is on that menu you can see the "Calibration" program which, like my old PDA, gives you crosshairs to tap to re-align the touch screen!
    Once I was able to navigate to the screen (it took several tries as my touch screen was very much out of alignment) I was able access the program and fix my problem!
    Hope this helps others!
    #6 youdiejoe, Oct 3, 2014
  7. illuminaut
    illuminaut New Member
    Does anybody know how to get to that 2nd level Product Diagnosis menu and the subsequent Calibration screen on a 3rd Gen? The instructions in the video do not work.
    Alive1 likes this.
  8. Arlene Vidana
    Arlene Vidana New Member
    Dallas, TX
    I am having the same problem but can’t get the touch to work to get to get to the screen with the arrows when you touch. Have you found a resolution?
    Alive1 likes this.
  9. Arlene Vidana
    Dallas, TX
    Did you ever find this? The Easter egg link no longer works
  10. Arlene Vidana
    Dallas, TX
    I bought a used 2007 Toyota Prius with Navi the touch screen is way off. I touch on right and hits buttons on the left and vice versa. I was able to get to the initial diagnostic screen and was able to get to the menu however I can’t click on the calibration. Any other ways?
    Alive1 likes this.
  11. bisco
    52,352
    is the touch screen black? sorry, i was responding to your first question. don't know what you can do at this point, all the best.(y)
  12. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    Four Touring
    I found this in the comments of a YouTube video:
    bigloo757 months ago
    I'm having same issue. and its random now. So, I went to calibration screen and then back to square one. it will still not fix it
    REPLY
    bigloo75
    7 months ago
    CORRECTION: it works now. got it fixed
    REPLY
    bigloo75
    7 months ago
    You need to go to Level: 2. Touch on INFO and flip lights 3 times. Then touch INFO again and flip lights 3 times again... you are in Level 2 and you will go to screen with calibration and Touch Switch option. Good luck!
    I'm not sure it really works as bigloo says, I can't get to our car right now, but it might be worth a shot.
    rogerdpack, SFO and bisco like this.
  13. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Sounds like you may need to get a used touch screen from another car with nav. I may have one, or you can check with Matt at Texas Hybrid Batteries. He's on here as well, and not far from you. I'm actually going to install one today for a customer.
  14. Swamp puppy
    Swamp puppy Junior Member
    Sykesville
    I found this link that worked for me to get to the 2nd diagnostic screen with touch screen calibration. Video is from UK so buttons on side of screen are opposite from US but everything else worked perfectly. Tip: use a pencil eraser end to touch screen and calibrate.
  15. rogerdpack
    rogerdpack Junior Member
    79
    Enoch, UT
    Guess you need the display to work to hit the buttons to fix the display...Saw someone who fixed it by pushing around the edges which circumvents that fwiw...
  16. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    I tried all stated methods calibrating the MFD until I realized it’s just the digitizer overlay screen that is bad/crap. Even if I would have managed to reach the calibration screen it think it would not have worked for very long.
    A basic (with some glare) digitizer for the gen2 can be bought cheap from Asia, ~ 20 euros. Not very complex to replace but surely not a leyman job. We were all leymen once…
    Here is a lovely tour of all the work required and good information:
    rogerdpack likes this.
  17. ChapmanF
    18,506
    If I'm not mistaken, the Tc to CG jumper that you'd use to retrieve blink codes also puts the MFD into the diagnostic menus. I remember it did in gen 1, anyway.
    priumium likes this.
  18. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Interesting! But when in that menu, I was unable to select anything since the touch is not working or registers wrong xy when pressed. I thought perhaps steering wheel buttons could move the menu selections, but gave up and replaced digitizer since I found no solution for this.
