Where Is The 12V Battery On A Gen5 HEV?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Sep 24, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    535
    172
    New York State
    2026 Prius
    Curious.
    I don't have the car yet...
  2. Paul Gregory
    Paul Gregory Senior Member
    2,124
    555
    Alberta
    2024 Prius Prime
    XSE
    Every Prius has had one.
  3. RX808
    RX808 New Member
    29
    17
    2025 Prius Plug-in
    XSE Premium
    Passenger side, rear, right inside the rear hatch
  4. VelvetFoot
    535
    172
    New York State
    2026 Prius
    So, you have to take out the foam to access it?
    edit: I'm not seeing an access panel here:
    #4 VelvetFoot, Sep 24, 2025
  5. Paul Gregory
    2,124
    555
    Alberta
    2024 Prius Prime
    XSE
    It's not big enough in my opinion. The factory 12V battery is 33 Ah, and it's not even AGM or lithium. It's the Flooded Lead Acid (FLA) type. But that doesn't stop them from selling it at $500.
    Mine was going dead at random times for no apparent reason, sometimes in as little as 2 hours.
    I have done everything possible to address this problem, but that hasn't stopped me from being attacked constantly by trolls in this channel who deliberately misconstrue the facts.
  6. VelvetFoot
    535
    172
    New York State
    2026 Prius
    Where is the battery located?
  7. Paul Gregory
    2,124
    555
    Alberta
    2024 Prius Prime
    XSE
    It's not in the floor panel. There is a black plastic cover over it, tucked into the right fender well.
    RandyPete, GcinFl and VelvetFoot like this.
  8. VelvetFoot
    535
    172
    New York State
    2026 Prius
  9. VelvetFoot
    535
    172
    New York State
    2026 Prius
    I found and consulted the 500+ page owner's manual. Less than helpful, but will attempt to read the whole thing anyway.
    Tells you where the jump location is under the hood, and bunches about how not to blind yourself and how complicated it is to put in a new battery, but nothing about where the battery is.
    I think they want you to go to the dealer for everything.
    I have read about problems with the 12V battery going dead.
    I have a charger on my lawn tractor that I plug in when not in use-didn't think the car MAY need it.
    Early days, I know, but is there room for a charger in/near the battery location?
    PrimeDan likes this.
  10. Paul Gregory
    2,124
    555
    Alberta
    2024 Prius Prime
    XSE
    I use a battery maintainer whenever possible. It has solved my problems for the most part, but occasionally the battery still goes dead. For this, I use a booster pack.
    VelvetFoot likes this.
  11. VelvetFoot
    535
    172
    New York State
    2026 Prius
    Do you have it permanently mounted, or do you pop the hood and clamp onto stuff?
  12. Paul Gregory
    2,124
    555
    Alberta
    2024 Prius Prime
    XSE
    I have it permanently mounted under the hood, so I can plug it in whenever I park near an outlet.
    I'd had problems with alligator clips, so I removed them and connected it directly with ring terminals.
    The plug sticks out like a block heater cord, but not too far, so that the wind can flip it around until it breaks the wires inside.
  13. VelvetFoot
    535
    172
    New York State
    2026 Prius
    In my case, I'd probably forget to unplug it. Having the plug in front might be less destructive when backing out of the garage.
    GcinFl likes this.
  14. Paul Gregory
    2,124
    555
    Alberta
    2024 Prius Prime
    XSE
    I've done that a few times; the worst that happened was the cord was stretched out before it unplugged.
  15. Mendel Leisk
    41,333
    Honda always managed to include oil and transmission fluid changes, ditto for light bulbs, air filters and wiper blades IIRC.
    It’s a little dismaying Toyota omits such.
  16. Paul Gregory
    2,124
    555
    Alberta
    2024 Prius Prime
    XSE
    I get the impression that Toyota supports ethical choices, except where the dealers are concerned.
  17. KMO
    KMO Senior Member
    1,947
    676
    Finland
    2023 Prius Prime
    RandyPete and VelvetFoot like this.
  18. VelvetFoot
    535
    172
    New York State
    2026 Prius
    Thanks!
    I guess I didn't look hard enough!
  19. RandyPete
    RandyPete Active Member
    403
    167
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    I have found the gen5 owners manual to be quite useful, especially if you get it in pdf format and use a word search tool to find what you are curious about.
  20. KCWhitney
    KCWhitney Active Member
    134
    116
    Connecticut
    2025 Prius Plug-in
    I have installed one in my gen 4, and found the car dead when I went to use. it. I was able to resurected it with a full charger, but was quite annoyed at the fact it went dead. Isn't this the point of a maintainer? Could I b doing some thing wrong? Is it worth complaining to the dealer whom I bought it from and installed it?
