Musty smell will not go away in my used Prius
Discussion in 'Gen 3 Prius Main Forum' started by sanshan, Aug 25, 2025.
  1. Grit
    Grit Senior Member
    6,568
    4,223
    Wilkes Land
    I’m too rich to do that said OP
    51,519
    that wasn't the o/p
  3. douglasjre
    douglasjre Senior Member
    2,141
    710
    Null, NL
    The dealer uses a two-step cleaning process for the evaporator. They spray the product up the drain tube. I recommend buying it at the dealer but if you feel better getting it on Amazon and risking a Chinese imposter have at it
    https://a.co/d/1datdGy Screenshot_20250904-010143.png
  4. ASRDogman
    ASRDogman Senior Member
    7,420
    3,863
    Any update? Did you do anymore cleaning? And if so, what did you use and did it work?
    douglasjre likes this.
  5. ASRDogman
    7,420
    3,863
    Weeeelllllllllllll????? :cool::sleep::sleep::sleep:
