Current leak
Discussion in 'Prius c Technical Discussion' started by Jean Benoit, Sep 24, 2025.
  1. Jean Benoit
    Jean Benoit Junior Member
    Québec
    2018 Prius c
    With my 2018 Prius C, there is a 3 amp current leak. Discharging the 12V battery. I don't have the patience to remove each fuse to find the leak. Where could the source of the leak be? Thanks
  2. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    Pay someone else to do that.
    It's not exactly a common problem, so somebody has to do real diagnostic work.
  3. rjparker
    10,411
    6,521
    An alternative to removing each fuse is to measure millivolts across each fuse. At 3 amps parasitic draw the millivolt reading will be very high.
    For fuses sizes up to 20 amps a 3 amp draw will create a 10 mv or higher voltage drop across the fuse. A larger fuse will read greater than 7.5 mv.
    The real skill comes after determining which fuse is feeding the draw. At that point wiring diagrams are usually needed to narrow down which load connected to that fuse is causing the draw.
    Normally it's an aftermarket device or a hatch light staying on.
    #3 rjparker, Sep 25, 2025
    Brian1954 likes this.
  4. Paul Gregory
    Paul Gregory Senior Member
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    I think you have better results from tracing the draw,
    instead of asking us to guess.
  5. bisco
    52,286
    do the interior lites stay on?
  6. Paul Gregory
    2,216
    586
    Alberta
    2024 Prius Prime
    XSE
    They do not. If they were, it wouldn't drain the battery in 2 hours.
  7. Jean Benoit
    Québec
    2018 Prius c
    Thank you all
  8. ChapmanF
    18,454
    Who said anything about two hours?
