Engine rumbling on start up and while driving
Discussion in 'Gen 3 Prius Main Forum' started by Cherry Killingsworth, Sep 24, 2025 at 7:41 AM.
  1. Cherry Killingsworth
    Cherry Killingsworth Junior Member
    Wichita, KS
    I have a 2010 Gen 3 Prius with 269,483 miles (as of posting). It started a few months ago. We changed the spark plugs last Saturday (an ordeal for another time) and it seems like it got worse. It's also had a recent oil change. We have noticed that the antifreeze is starting to run low after just a few days. We keep refilling it. We are at our wits end because we can't afford another car and we love this car. I tried to attach a video of the engine noise, but the file is too large.
  2. ASRDogman
    ASRDogman Senior Member
    7,421
    3,865
    The head gasket has failed..... That's why you are loosing coolant.
    That's why it knocks on cold starts. It has likely failed between #1 and #2 cylinders.
    If you fix it now, you might only need to have the head gasket, and hope the head is not warped.
    If you wait, and continue driving it like it is, you risk bending a rod, or having it go through the block.
    If you are able to replace it yourself, it will cost you a lot less money. Labor is a lot.
    PriusCamper and Brian1954 like this.
  3. Tombukt2
    12,679
    2,263
    Another car and soon another engine in the car you love . Quite costly for 300K mile car.
  4. Tombukt2
    12,679
    2,263
  5. Grit
    Grit Senior Member
    6,570
    4,223
    Wilkes Land
    Good run. Replace head gasket and do the illegal commieformia oil catch can install or replace vehicle.
  6. Mendel Leisk
    40,972
  7. Mendel Leisk
    40,972
    Since new, recently acquired? That’s a LOT of miles for a gen 3. Head gaskets, on ones without regular EGR cleaning, usually fail around 150~200k miles.
