Car Shudders on Deceleration around 37-38 MPH
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2genowner, Sep 25, 2025.
  1. 2genowner
    2genowner New Member
    Rhode Island
    Got a new issue that I would like to investigate in case something else is starting to happen.
    for the last month or so (interment) the car shudders when doing a slight decel around 37-38 MPH.
    Some times if it shudders enough the traction control warning light flashes and then goes away
    the would be a decel but no braking so a coast but with the inverter charging HV battery from wheels turning. Usally when maybe just around 40 or slightly higher and take foot off gas pedal to start the coast. tonight i drove with the defroster on (with AC) and it seems to do it allot less or at least to the point where it was not a big noticeable shudder.
    Was not sure if this was the transmission doing a gear shift or the ICE engine doing something weird.
    Car has new Plugs, Injectors, Coils, MAF sensor, Both O2 sensors (having an issue with upstream one after replacement throwing a code for P2238 so I am waiting for another O2 sensor assuming this one was defective) but the shudder was happening before O2 sensor was replaced
    #1 2genowner, Sep 25, 2025
  2. 2genowner
    Rhode Island
    Sorry forgot 2006 Prius with 230k +
  3. saneesh8
    saneesh8 Member
    208
    52
    Allen, TX
    Injectors, are they OEM ? Also any code ?
  4. JC91006
    JC91006 Senior Member
    16,814
    8,596
    I hope you used all original OEM parts when you replaced plugs, coils, injectors, maf sensor, o2 sensors, etc. If you used an aftermarket part, any one of those could cause the problems you're experiencing.
  5. saneesh8
    saneesh8 Member
    208
    52
    Allen, TX
    The sensors, in particular, use OEM or same level. Cheap ebay/online made in China parts wont work. They even pack it in boxes looks like genuine. Most of the time, they don't work out of box or stops working after few days.
    For my Odyssey, I got burned once from an ebay vendor with spark plugs which came in Honda labelled packing. All fake and i was lucky to check it after 3k miles. It was almost ready to disintegrate and on my bmw, the cam sensor, the cheap one threw code immediately. Not worth wasting time trying with these.
  6. 2genowner
    Rhode Island
    Injectors OE but rebuilt. MAF and coils OE, Spark plugs Iridian but maybe not OE, O2 sensors not OE hence probably why i got a defective one. But why is it mainly at one speed and during mostly a decel? It almost seems like a upshift and engine release at the same time and why would it be better when AC is running?
    Forgot to also mention I removed throttle body and cleaned it. some oil in bottom of intake manifold that i mainly coaked up with a rag. Also the some times Traction light flashing? the car runs great other wise.
  7. saneesh8
    saneesh8 Member
    208
    52
    Allen, TX
    The throttle body, i guess it can do it if stuck or sensor not reading position properly. No error codes? Can you try with a proper scan tool? flashing traction light may set a code in the module.
    I didn't had to do it when i replaced the throttle body, but wonder if it needs relearn like other cars. Also all vacuum / air lines are connected?
  8. 2genowner
    Rhode Island
    got decent scan tool. not top of line but not cheap junk either only code right now is P2238 I replaced O2 sensors because was getting code P0172
  9. saneesh8
    saneesh8 Member
    208
    52
    Allen, TX
    Lets check it after O2 sensor replacement . Any difference in the behavior if you unplug the O2 sensor?
  10. Tombukt2
    13,270
    2,396
    Maybe check at least your front tone rings cleanliness and wires in good shape eratic signal from tone rings missing squares or severely clogged w debris
  11. PriusCamper
    PriusCamper Senior Member
    12,982
    5,278
    Pacific Northwest, USA
    Can you please be more descriptive about what the "shuddering" is that you're experiencing? I just looked up the definition of this word and kinda know what you're saying but that's not a very descriptive word for this symptom?
    I see this problem on here sometimes... People obsessed with replacing parts that never needed replacing tend to be hyper sensitive to tiny noises and vibrations when in reality you car is near 19 years and is going to have all kinds of weird creeks and groans and old worn out car funk going on.
    Point being, Prius are super reliable and you're wasting time and money on all these unnecessary details and expenses. Just enjoy your life and your old car and wait for warning lights or obvious symptoms before thinking there's something wrong with your car because it's old.
    #11 PriusCamper, Sep 25, 2025
  12. 2genowner
    Rhode Island
    Shuddering like jerking. I know this shudder / jerk a little but this is getting what I feel is bad. And something is going to break or wear a little faster. Allot of the other parts where for reasons. Plugs coils and injectors when I first got car. Tune up and was having misfires, ended up being #1 injector bad and not working. Then the p0172 rich. Cleaned maf first but did not help so replaced it. Then while semi apart cleaned throttle body. O2 sensors next. After replacing upstream sensor no longer rich but the other code about low circuit on heat in o2 so waiting for next replacement one to come in. Wiring connector to hard to get to so I will test that once replacement sensor come in since I don't want to take apart wiper Cowell three times . Today it seemed to do the jerking again but at low speeds so it seems like when the ice is disengaging is more when the jerking is happening. Disengaging/ turn off? I just want to make sure this is not a sign of something else starting to go wrong and asking the community to see if this was something known.
    #12 2genowner, Sep 25, 2025
  13. PriusCamper
    12,982
    5,278
    I always try to avoid replacing/cleaning fuel injectors as much as possible because all kinds of additional problems tend to happen. If I were you I'd do a Google or DuckDuckGo search on "PriusChat posts fuel injectors P0172"
    #13 PriusCamper, Sep 26, 2025
  14. PriusCamper
    12,982
    5,278
    In other words, "I hope you have unquestionable obedience to the delusional cult of OEM so you spend 5 times the price on every part your car needs even though near identical aftermarket parts, as well as used parts cost pennies on the dollar."
  15. dolj
    dolj Senior Member
    8,516
    4,323
    Wellington, New Zealand
    My experience with that particular shuddering is when the hybrid vehicle battery starts to get low in capacity. A cycle of charging/discharging to balance the pack can fix it.
    PriusCamper likes this.
  16. JC91006
    16,814
    8,596
    I see you have always have this stance on OEM parts. I've used these aftermarket parts before, therefore I can say with experience that they are inferior.
    Labor is not free, when you replace parts over and over again, the labor cost can be extremely high. A quality part doesn't require replacement as often. Inverter pumps that you talk about a lot from ebay for $20 will last 2 years at most, while an oem part cost 5x as much but will last 8 years or more.
    Quality parts engineered to last, like in all new Toyota cars from the factory, will outlast any cheap aftermarket part. There is a reason these Toyota cars require almost no replacement parts for the first 100k miles.
  17. 2genowner
    Rhode Island
    Update. Replace the Upstream O2 sensor again and back to original code P0172 (Too Rich).
    The Shake / Shudder / Jerking seems to have gone back to the normal Mild / ;light shudder. I guess I will put Original Injectors back in to see if that is indeed the current problem. but for now the Violent shudder has seem to go away.
    #17 2genowner, Sep 30, 2025
  18. 2genowner
    Rhode Island
    I can confirm that the Violent Shudder has gone away and just has the Prius normal mild shudder when engine shuts off.
    Bad Replacement injectors causing the p0173 and the defective replacement up stream O2 sensor was the reason for the other code. It has been two days now. And I guess I am also ready to complete my state inspection now that my MIL light is off
  19. JC91006
    16,814
    8,596
    I'm glad replacing these parts with a quality part fixed the problem. Many times when you use inferior parts, new but at a lower price, can often create problems you didn't originally have. So if you want to keep your car running good, use only OEM parts on critical parts (all the ones you replaced)
    Brian1954 likes this.
  20. saneesh8
    saneesh8 Member
    208
    52
    Allen, TX
    Where did you buy the rebuilt OEM injectors? hopefully it was OEM and not fake.
    I think rebuilt means, replace the micro filter and clean it properly with ultrasonic cleaning. If the electronic part is not good, it is not going to work.
