non-Blue LED standard headlamp replacement
Discussion in 'Gen 2 Prius Accessories & Modifications' started by [email protected], Sep 25, 2025.
  1. priestbh@gmail.com
    [email protected] Junior Member
    I have a 2007, that was in minor fender bender in 2008. After repairs I could not get a standard drivers side headlamp to last more than a year. After having to go to dealer once and local shops second time, the third time I did myself and discovered the joys of gen2 headlamp inaccessibility. The fourth time around I bought an aftermarket LED replacement, thinking that LEDs have no filament to bounce around. And that worked great for about 6 years-ish (it's been a long time since I have had to change a headlight). However 6 years ago Virginia had not passed Anti-Blue headlight laws. So now I need an LED replacement as far down the color temp scale I can go. Most replacement say 6500K or 6000K and those are going to be blue. I have searched Amazon, google, rockauto, and ebay, and not turned up what I want. Does anyone have a recommendation for an LED replacement for the standard bulb (h4 or 9003 base i think it's called?) that is under 6000k color temp?
  2. xw20_driver
    xw20_driver Member
    101
    53
    PNW
    I have a set of these Philips UltinonSport 9003 and they are listed as up to 6000K. I personally perceive them as white without any hint of blue to my eyes.
    BiomedO1 likes this.
  3. BiomedO1
    4,131
    2,169
    SacTown, Ca
    Unless your state law states that color temperatures at 6K and above is illegal; I believe it should be OK. 6K is pure white, 6.5K has a blue tinge to it. You can buy a 3K-3.5K color temperature lamp that'll yield an auburn glow, like an incandescence bulb. I use those in my fog lamp setup. The newer ones can actually switch between white and auburn lamp colors.
    Also make sure that your headlamps are legally aimed properly; so as not to blind on-coming traffic. I know my old 2012 Prius C had a very nice lens that accepted a LED swap-out very nicely.
    YMMV
    FWIW; I believe all new car LEDs are in the 6K color temperature range.
