P0016 after head gasket replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by robbiebags, Sep 25, 2025.
  1. robbiebags
    robbiebags Junior Member
    long island, new york
    Hey guys, I just finished replacing the head gasket for my 2011 prius with 195k miles. Unfortunately, during start up, the engine was still rattling after 10 seconds. Didn't smoothen after a minute so I shut it off. Threw a P0016 code which is timing related. I think I put the timing chain incorrectly(attached is a photo of it). Only 1 mark was correct which was on the intake side cam sprocket. As for the exhaust side cam sprocket, I couldn't reach the mark with my chain's 1 link mark, I'm about 2 teeth off, that's because the intake side cam sprocket turned clockwise by like 15 degrees when the tension was released. I tried to turn the intake cam sprocket counter clockwise so I could reach the mark on the intake but it wouldnt turn. I didn't want to force it either. I was looking into reddit and some stated that it should correct itself after the engine starts. Obviously it didnt after starting the engine after putting everything back together. My heart kinda sunk. I spent 20 hours on this job already.
    Now I have to disassemble the engine again to get to the timing cover and fix the timing. When i was retracing my steps, I realized that the reason why i couldn't turn the intake cam sprocket counter clockwise was because the chain was already installed on the bottom crank sprocket. I now have an idea how to correctly place the marks and hopefully fix the timing issue.
    My question is, did I do any damage to the engine from letting it run for a minute with bad timing? Also, when I go back into the timing chain after disassembly, would all my sprockets be misaligned now due to the improper timing and now have to rotate them? Or do I just have to place the chain in correctly this time?
    This is my biggest DIY on a car ever. Just didnt have the funds to go to the shop. They charged at least $3000 for the job.
    Any input helps. Thanks in advance guys!
  2. PriusCamper
    PriusCamper Senior Member
    12,796
    5,180
    Pacific Northwest, USA
    I've read a bunch of posts like this over the past dozen years and have never seen serious damage from timing sprocket position being slightly off.
    robbiebags likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,608
    3,916
    Do your best NOT to rush this. Go slow and pay very close attention to the marks and
    the chain.
    Put the engine at TDC first before pulling the timing cover off. With the valve cover off.
    Make sure the sprockets align for TDC, they should be very close, but off because the chain
    of off.
    AFTER you've align the cam to put the sprocket in the correct position.
    If you take cam cover off nearest the
    sprockets, and fold a paper towel a few times and place on top of the cam then put the cover
    on and snug it up, this will keep it from moving.
    Now you can install the chain. It should be tight along the top between the two sprockets.
    And tight between the intake sprocket and crank sprocket.
    The chain will stay tight, and only be loose on the tensioner side. Push the chain toward the center,
    it will more or less stay in place. Carefully install the timing cover.
    Then the tensioner. Of course, you should have retracted the tensioner and rotated the hook to
    keep it inside the tensioner. After installation, you rotate the crank, SLOWLY, counter clockwise,
    which will push the piston back a little and the clip will release, and you'll hear it.
    then rotate the crank back to TDC.
    Then remove the cam shaft cover, and remove the paper towels. Reinstall the cover and torque to specs.
    This is the IMPORTANT part. It's easier with the spark plugs removed. Rotate the crank 720 degrees, two
    full turns. Make sure the mark is at TDC. Then check the intake and exhaust sprockets. They SHOULD
    line up in the correct positions. The timing CHAIN special links will not, that doesn't matter, the sprockets
    must align correctly. If they do, you're all set.
    If you rotate the crank 30 times I think it is, THEN the links on the chain will align with the sprockets.
  4. robbiebags
    Dude you are the best. Thank you for the write up! I'm understanding everything you've said. I've done hours of research last night on how to fix my timing especially now that it's off timing for sure, but couldn't really find anyone with a video on how to fix it if it's misaligned.
    My question is, how do you align the cam to put the sprocket in the correct position? Do I use a 24 mm wrench to turn the cam? Do I go clockwise or counterclockwise? Also, I'm sure both intake and exhaust sprockets will need to be turned because of the mistiming right?
    Thanks again man. You are a lifesaver. I will be working on my car this weekend a few hours at a time and will post updates here if I hit a roadblock with the timing.
  5. ASRDogman
    7,608
    3,916
    You're welcome.
    I'm not sure the size of the wrench, it could be 24mm, but whichever size it is, yes...us it to turn the cam.
    If you have someone to help, it will be easier. Just make sure you are at TDC. You shouldn't have to turn
    it much though. And the valves can hit the top of the pistons, keeping you from turning the cam.
    While one holds the cam in place, the other can install the towel in the cam bearing, and snug the cap....
    DO NOT OVER TIGHTEN!!!! Something will break! NOT GOOD!
    I'm not sure which video I watched to get that idea. But it is a good one! (y)(y)
    P.S. You can go either way. You are only moving it 1 tooth or 2 teeth.
    When you think you have it correct, push the timing chain on the tensioner side to take up the slack.
    Then double and triple check the timing marks. Make sure there is NO slack at all between the
    exhaust cam to the intake cam (top part) and no slack between the intake sprocket and the oil
    pump sprocket and then to the crank sprocket.
  6. robbiebags
    Is this the video you're referring to?
    On that video, he turns the sprocket bolt to get to the correct marking. He spun the bolt a few times too, almost a full rotation on both camw. They both landed on the correct marking without needing to hold a cam in place while putting a towel. Will I have a different experience because of my incorrect timings?
    Hopefully I don't have to call my wife to help me for this job. She already got her hands full with the kids
  7. robbiebags
    So I got to do an hour of work on the car today. Got the valve cover off. Now I'm trying to set the timing to TDC. However, the crank wheel is not on 0. I'm pretty sure I'm on TDC. is this because of the misaligned chain?
    I've attached 3 photos showing the 3 sprockets at what I think is TDC.
    I guess once I remove the timing cover, then the tensioner, then the chain, I can rotate the crank sprocket to it's proper marking like the intake and exhaust can sprockets?
    Let me know. Thanks!
  8. ASRDogman
    7,608
    3,916
    Yes, the timing is off.
    Remove the tensioner first....then the cover.
    Are you certain you are at TDC for the compression stroke?
    Are the spark plugs removed? If so, you can look at the #1 piston to make sure
    it's up.
    With the timing that far off, I'm surprised you didn't bent a valve.
    What you might have to do is turn the crank back to get the piston about half way, that way
    all the pistons are half way. That way when you remove the chain, the pistons are away from
    the valves so you can rotate the cams to put them in the correct spot for the chain.
    Then rotate the crank back to TDC, and install the chain.
  9. ASRDogman
    7,608
    3,916
    double post?
  10. robbiebags
    Oh boy. So the timing is that far off huh? I honestly won't be able to tell if I bent a valve. No experience with that yet. But I did run the engine for a total of a minute ish during start up after I changed the head gasket.
    Maybe if I set the timing right later tonight and put everything back together and start it up, if the engine isn't running smooth, then I guess I bent a valve.
    As for rotating the crank not to TDC but halfway as you have recommended, should I try setting the timing on the intake and exhaust cams first with crank at tdc first and see if im successful?
    Yes I removed the spark plugs already to make it easy to crank. Thanks again for your input!
  11. robbiebags
    I got photos of the current timing. Do you think I bent any valves? I really hope not. What do you think? Because if the likelihood is high enough, no point putting the timing cover back on but instead remove the head and bring it to the shop.
    Thanks for your input.
  12. ASRDogman
    7,608
    3,916
    A bent valve is possible, but that doesn't mean you did. Do you have a bore scope? You can look inside the
    spark plug and see any damage on the top of the piston.
    You just want to move the pistons down so you can turn the cams. You can also look at the valve stems and see
    if any of them are not all the way up.
    If they look okay, you might as well set the timing chain correctly, and if you dare, slowly rotate the engine,
    and have someone keep pressure on the left chain tensioner, two complete revolutions, and check the timing
    marks,and look at the valve. Make sure they all go down and up easily, and the same as the others.
    If everything looks and sounds okay, put the timing cover back on, install the tensioner, and valve cover.
    And try the engine again. Hopefully it runs correctly, and smooth.
  13. robbiebags
    I was able to work on it earlier and set the timing right this time around. I attached a video of me hand cranking it 720 from TDC. Everything is still lined up which is good. However, I can't tell if a valve is bent. Let me know what you think. Not sure if there's an abnormal sound there. Thanks again!
    https://youtube.com/shorts/gYQoZdw-Au4?si=7C92kPP48LR1-SNh
  14. ASRDogman
    7,608
    3,916
    I HATE what youtube has done with the view. No time bar so you don't know what it stops and starts.
    It just loops. NOT YOUR FAULT.... stupid youtube. If all the marks lined up, you're set.
    Hard to tell if a valve is bent, without looking. A bore scope would be best.
    Once it starts, you'll likely know.... You probably don't have a bent valve, but without looking, you don't
    really know.
    Good luck!
  15. Mendel Leisk
    41,525
    Good video regarding timing chain:
  16. robbiebags
    I put everything back together. How's the idle?
    https://youtube.com/shorts/e75SFv6xLdw?si=Y6rCWiY0Rq83-HK_
  17. Mendel Leisk
    41,525
    Sounds good. :)
  18. robbiebags
    Thanks for the switf reply. Is that ticking noise okay?
  19. ASRDogman
    7,608
    3,916
    Doesn't sound too bad. Have you driven it?
    If a valve is bent, it won't seat, so there will be an air leak, and no compression.
    Only 3 cylinders will be working. If it drives well and you have power, then you
    are probably okay.
    Keep an eye on the coolant tank, and monitor the coolant temp. You don't want it overheating.
    robbiebags and Mendel Leisk like this.
  20. robbiebags
    Car is up and running. Drives so much better too. Thanks for everything guys! You guys rock
    Here's my documentation of everything, mostly me struggling lol
    Mendel Leisk and ASRDogman like this.
