ABS warning lights after catalytic converter replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by Travis Antonissen, Sep 28, 2025 at 1:26 AM.
  1. Travis Antonissen
    Travis Antonissen New Member
    Today
    United States
    2015 Prius. Catalytic converter was stolen. Took it to the mechanic to replace under insurance.
    Car worked for a couple days, now have ABS warning, traction control, and parking brake light permanently on. I hear the brake actuator cycle on very quickly.
    Whats the most likely cause of what the mechanic messed up?
  2. BiomedO1
    3,151
    1,667
    SacTown, Ca
    It may not be the mechanic's fault, but damage that was missed when the thieves stole your CAT. Everyone was concentrating on the missing CAT and nobody did a full inspection of the undercarriage. Thieves could've done some damage when jacking up the car to steal the CAT, the shop could've damaged it when they jacked it up, or you could've ran over something that ripped down something down in the ABS system.
    Good Luck.......
  3. ChapmanF
    17,757
    We need to start by asking the car what it thinks the problems are.
    If you don't have a suitably-capable scan tool for doing that, then do this:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    Once we know what problems the car is reporting, we can reason about whether they were likely caused by the mechanic, or by the thief, or by something else.
    Whatever the answer to that is, we will at least know what it is that needs to be fixed.
    Brian1954 and BiomedO1 like this.
