Need help with deciding on new shocks for gen 2
Discussion in 'Gen 2 Prius Technical Discussion' started by amitt, Sep 10, 2025.
  1. amitt
    amitt Junior Member
    52
    2002 Prius
    I
    Hi chat members ,
    My 2006 prius has 225k miles and original shocks. I had the car since it had 93k miles, and i never felt it had a soft ride, not even when comparing it to my gen 1prius, that always had more miles than the gen 2, both with original shocks.
    Given the rough ride " by design", i would really appreciate your thoughts on whether it is worth it to spend the money on new shocks, and if so, is there a way to buy a brand that will be more comfortable than the OEM shocks?
    I have a really bad back, and i feel every bump, even those little lane seperators light reflectors ( pavement markers) go straight to my gen 2 chassis and into my neck and spine.
    Did you get a huge improvement by replacing shocks on your gen2? If so, what brand was it?
    BtW, the shocks do not leak, and the car does not bounce a few times when shaking it, it stabilize after 1 bounce ,so the shocks are not " completely shot" like the suspension is hanging on the springs alone.
    Thanks!
    #1 amitt, Sep 10, 2025
    51,853
    are you running spec tyres pressure?
  3. amitt
    amitt Junior Member
    52
    2002 Prius
    I
    Yes i have Bridgestone ecopia e150, with 35 in front, and 33 in the back, while cold.
    On the costco air pump, they recommend to put +4 PSI from the above numbers, if the car was driven more than 4 miles. So I always set to 39PSI front, and 37PSI back, after driving there to fillup the gas.
  4. bisco
    51,853
    might be a good idea to buy a tyre gauge
  5. Hayslayer
    Hayslayer Active Member
    390
    219
    The gentleness of your ride will improve drastically if you drop your tire pressures to 32 front/30 rear. Your mpg will reduce slightly, but feeling every pebble on the road will practically go away. Adjust a psi or 2 to find what works best for you. It's always a compromise between comfort, harshness and mpg.
  6. douglasjre
    douglasjre Senior Member
    2,172
    716
    Null, NL
    KYB from RockAuto
  7. ebikeman
    ebikeman Member
    105
    Northwest
    Driving 4 miles wouldn't do a thing to my pressure. I'd put it at the pressure on the door.
  8. Hayslayer
    390
    219
    If this was my problem, I'd be running mid to high 20s psi in the tires. 25-29 psi is plenty to support the car for normal driving and will really soften bumps. Tires are available all day long if they wear a bit funny. Backs? not so much.....
    Is your car equipped with OEM size rims and tires (15 inch rims with 185/65 tires) What is your normal daily driving routine?
    #8 Hayslayer, Sep 14, 2025
  9. amitt
    amitt Junior Member
    52
    2002 Prius
    I
    Thanks for your answers guys
    Douglasjre- did you feel a dramatic change after changing to KYB? What is quick struts? How many miles did you have?
    Hayslayer- yes original 15 inch rim and size, ecopia e150, which i driven on in the last 25k miles, the rear had barely any wear on them, so i assume this rubber is very resilient.
    I drive some highway some city, if the highway had many transition between concrete bridges ro asphalt, i definitely feel that the car is rough on me.
    My 2006 sienna with 99k miles and original shocks take those transitions better, but not perfect either
    Ill try to reduce the air pressure at what PSI is it starting to be unsafe?
  10. douglasjre
    2,172
    716
    Null, NL
    Quick struts is aftermarket trash. KYB is OEM equipment. It's the best for that price. No need for Bilstein upgrades. Not even sure if Bilstein offers a B6 for this car. Wouldn't need it anyway. Sachs isn't quite as good as KYB but it's comparable. Just get KYB and be done with it. Do it correctly the first time and you won't have to do it a second time
  11. amitt
    amitt Junior Member
    52
    2002 Prius
    I
    I found the whole quick strut assembly from toyota dealer for 140 per front quick strut,and 70 for each of the quick rear strut, meaning including the spring ,plate , bump stop, etc. Its about double than buying the KYB shock only from amazon, but then i wont have to mess with the labor of compressing the spring and replacing the plate bump stop etc in case its bad, did any of you buy the whole quick strut from toyota? Is it worth it?
    Will i feel a dramatic change in comfort, or is it going to be only 10-20% different?
    Theres a guy on youtube that did the front, and at the end of the video he said that " honestly over bumps it's the same, it just feels like a new car"
    Minute 12:43 is when he test it...
    Im not sure what that means , but if this means that this car is uncomfortable by design and the difference between a shock that has 200k miles but not leaking, and definitely not completely shot, is a minimal difference, im not sure i want to get into this.
    Any real life experiences with before/after will be greatly appreciated.
    Thank you
  12. xw20_driver
    xw20_driver Junior Member
    PNW
    I just replaced front struts last weekend in my 2007 Touring and did the rear shocks earlier this year. I went with KYB front struts and rear shocks from RockAuto.
    If you are getting complete front struts from Toyota and they are OEM (strut, mount/bearing, coil, upper coil insulator/boot, lower coil insulator) all for $140 each, that is an unbelievably great price. I'm doubtful given the OEM strut is listed as $159 before discounts (pn# 48520-80064) and KYB quick struts at RockAuto are $149 each. But if your Toyota dealer parts counter is selling complete front struts at that price I would say go for it.
  13. douglasjre
    2,172
    716
    Null, NL
    Amazon might be Chinese fakes. Don't do that. And I don't know who sells complete assemblies. Get the parts at Rock Auto and get a spring compressor. Grease the Torrington bearings when u get the struts apart
  14. pasadena_commut
    pasadena_commut Senior Member
    2,591
    768
    Southern California
    It doesn't sound like there is anything wrong with the OP's car's suspension. If the OP has a back problem a seat modification might be more effective than changing the suspension. Since there are all sorts of types of back pain, and the seat fix for one might make another one worse, I'm not going to speculate on which would be best in this case. In particular, while it would be tempting to put an inch or so of something like memory foam on the seat bottom, that will change the body position with respect to the rest of the seat, and that could well be counterproductive. Seems like the sort of problem where one should consult a medical specialist, an MD, physical therapist or possibly even a chiropractor.
    Off road racers have a somewhat similar issue, and they often resort to special seats to help cushion the blow. Some of those companies also sell seats for people with back problems. (Back problems are really common.) Perhaps worth having a chat with them. Here is one such company (just because it came up near the top in the search, this is not a recommendation!):
    Custom Off-Road Suspension Seats | PRP Seats
    Be aware that the seats which can absorb the biggest bumps also cause the rest of the car to move much more than is normal with respect to the driver, so the tradeoff is that during a big bump the steering wheel and pedals will appear to move up and down a bit. I expect that this wouldn't normally be an issue while driving on paved roads, even slightly bumpy roads, but it might be when driving over a speed bump or through a dip.
