Hello. I have a 2012 Toyota Prius 3. It has 200k miles, battery is still working but its not currently drivable due to a blown head gasket from the water pump going out. Everything else in the car was in decent working condition. It has a new water pump as well. Could anyone tell what it’s worth and what I should sell it for?
if there aren't any newer systems in the car, (brake actuator, battery, etc.) it's probably time to donate it to charity
Water pumps are prone to failure, best replaced every 100k miles to play it safe. Was the EGR system (including intake manifold EGR passages) ever cleaned? If not that's a likely contributor to the head gasket failure. How's the oil consumption?
