Steering wheel cover
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Keith Kerns, Sep 4, 2025.
  1. Keith Kerns
    Keith Kerns New Member
    Jacksonville
    XSE
    Hi Everyone. I just bought my first Toyota Prius. 2024 Prime XSE. I got a leather steering wheel cover that I’d slightly too big. Does anyone have a suggestion on altering to make fit or a suggestion on the best one to get for perfect fit? Thanks
  2. VelvetFoot
    VelvetFoot Active Member
    1,146
    453
    New York State
    2026 Prius
    I'm waiting on mine.
    Just recently I tried putting on a sew-up leather cover on a Crosstrek. Couldn't make it work, I felt, with all the smart features of the the steering wheel.
    I had a 2000 VW beetle that I put a sew up one on and it was great.
    For the Crosstrek, wound up getting a slip on 'leather' cover, ie, no sewing. She likes it.
    You have to get the right size. Maybe you can exchange it? They're not that expensive.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    +1 to getting the right size, this cover from Amazon was thin enough at the edges to tuck under the plastic bits of our 2025 Toyota Crown Signia steering wheel. FYI, the cover comes with thread to sew the cover on, but I don't use it because it is made of a slick synthetic material. I get a waxed thread that is thicker and easier to use.
    https://a.co/d/5F5MH1U
    The Signia has a factory real leather steering wheel already, but we prefer a nice, thick steering wheel.
    https://a.co/d/bSMWZ1J 20250304_233633.jpg 20250304_233724.jpg
    VelvetFoot likes this.
  4. VelvetFoot
    1,146
    453
    New York State
    2026 Prius
  5. Humble Bear
    Humble Bear Member
    131
    49
    Arcadia, CA
    2024 Prius
    That was a marvelous steering wheel job you did. Was that a custom-made steering wheel cover because I see that there were bulging areas at 2 & 10 o'clock position and then the cover conforms to the bottom spoke?
  6. xliderider
    8,140
    3,277
    Honolulu, HI
    Nope, off-the-shelf cover, linked in previous post.
    The bulged areas at 10 and 2 aren't completely covered, there's a slight gap between the edges.
    As far as the bottom of the wheel, the cover is tucked under the plastic trim with a spatula type trim tool. The cover is tied off directly adjacent to the bottom spoke, then the lacing continues on around the steering wheel.
  7. VelvetFoot
    1,146
    453
    New York State
    2026 Prius
    I might give it a try when I get the car!
    Too bad it's not heated, but you don't have that problem where you are, lol.
    xliderider likes this.
  8. VelvetFoot
    1,146
    453
    New York State
    2026 Prius
    I just now clicked the link to the steering wheel cover. That's the same one I got, but different size, that I gave up on my Crosstrek attempt. I like what a saw though, quality wise.
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    Yeah, I put the same covers on my two son's 2017 Subaru Imprezas, one hatchback and one sedan.
    At the time, I did not try to tuck the covers under the plastic pieces on the steering wheel, so I went over them. Doesn't look as good as the one I put on the Toyota Crown Signia.
    I'm showing the cover I put on a 2016 Corolla as well. I have a closeup shot of the gap at the 10-o'clock position. 20240831_144450.jpg 20220904_105311.jpg 20220904_105437.jpg
  10. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I just have to say that I absolutely love the feel of the Toyota material and would never put a cover over it. But different people have different preferences and there's nothing wrong with that.
  11. VelvetFoot
    1,146
    453
    New York State
    2026 Prius
    But you probably have a deluxe model!
  12. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The material is the same in all models. The only differences between trims/models is that the bottom trims(LE & SE) don't have heating elements, and the HEV models(LE, XLE & LTD) don't have capacitive touch sensors and the control module. Externally, they're all identical.
  13. VelvetFoot
    1,146
    453
    New York State
    2026 Prius
    Wow. The high enders don't get leather?
  14. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's not real leather, but it feels like a super-smooth leather-like surface. It's not hard plastic or anything. Best feeling steering wheel I've ever used(including a couple leather Mercedes wheels from many years back).
    Just wait until you get yours and give it a feel before you commit to a cover. Maybe you'll like it, maybe you won't.
  15. VelvetFoot
    1,146
    453
    New York State
    2026 Prius
    Yes, I will.
    I love how the cover's ad in Amazon hints that it might be fun spending 2 hours (their estimate), sewing the thing on.
    I did it once, on my VW, and I would not say it was fun. :)
