Thoughts on Keeping a 2004–2009 Prius Running Strong
Discussion in 'Gen 2 Prius Main Forum' started by Thomaswhite9698, Sep 29, 2025.
  1. Thomaswhite9698
    Thomaswhite9698 New Member
    United States
    2012 Aqua
    Hi everyone, I’ve recently joined this community and I’m excited to share and learn. I own a 2007 Prius (Gen 2), and I’d love to hear your tips and experience on long-term maintenance.
    A few specific questions I have:
    What maintenance tasks do you recommend doing before serious trouble starts (e.g. inverter, hybrid battery, coolant, etc.)?
    Which upgrades or replacements have given the best value/performance improvement for the Gen 2?
    Any advice on reliable sources for OEM parts or trustworthy remanufactured components?
    Thanks in advance for all the help. Looking forward to contributing to this community!
  2. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    How many miles does your 2007 have? That will affect some advice.
    Otherwise change transmission fluid, both coolants, brake fluid
    Change oil and filter every 5k mileage
    Clean the hybrid battery fan
  3. Mendel Leisk
    41,628
    Attached a couple of spreadsheets (and pdf conversions), table format summary of the event-by-event schedule published by Toyota USA. One per the booklet, the other extrapolated to 240k miles.
    I'd be looking into:
    1. Brake inspection
    2. Brake fluid replacement
    3. Coolant replacement (engine and inverter
    4. Coolant pump replacements (engine and inverter), plus coolant thermostat on the engine.
    5. PCV valve replacement
    6. Spark plug replacement
    7. Engine oil and filter replacement
    8. Engine and cabin air filter inspect and/or replacement
    9. Wiper blade inspect and/or replacement
    10. Throttle body cleaning
    11. Tire inspection
    12. Rodent proofing
    13. 12 volt battery inspection and maintaining
    14. Hybrid battery inspection and maintaining
    15. Thorough wash including wheel wells, occasional waxing, interior cleaning
    Depending on where you are in the "USA", rust mitigation may be a consideration as well.
    #3 Mendel Leisk, Sep 30, 2025
    priumium, bisco and nancytheprius like this.
  4. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    My cents:
    * Check/fix brake pins and rubber boots, they are often in bad shape and destroy the mpg and the actual brakes.
    * Use a ctek or similar charger with an extended connector to easily keep 12V healthy.
    * Check and clean throttle body and MAF with carbon solvents/propanol - or more expensive products….
    * Install front splash guards and if in rusty geography, check rear wheel front arch/rocker for very common rust issues. Open if bubbly paint, rust prevent with raw linseed oil or similar and re-seal.
    * OEM: I nowadays only buy OE from amayama.com, shipped from Japan. It’s cheaper and smoother compared to dealerships (duh) OR toyotaparts sites.
    Also, their active blueprints are genius and show all components from the manual with clickable context in the pictures.
    https://www.amayama.com/en/genuine-catalogs/epc/toyota-europe/prius/NHW20L
    #4 priumium, Oct 1, 2025
  5. Mendel Leisk
    41,628
    ^ for #4 in my previous list, definitely research the need for replacement first. And the interval.
    I’m more familiar with gen 3, where the two water pumps, the engine one in particular, are failure prone, by 150k miles, so every 100k is prudent replacement interval. Not that familiar with gen 2 though.
  6. nancytheprius
    365
    156
    iowa
    Agreed, my gen 2 inverter coolant pump went bad around 130k. It’s not difficult to replace, so maybe just save the money until it’s actually needing to be replaced
  7. Mendel Leisk
    41,628
    Off-topic: with gen 3 removing the inverter coolant pump is frustratingly difficult: it's VERY reachable from below the car, but one or more of the fasteners is not accessible from below, and the only apparent way to get it out is from above, by first removing the entire inverter. Definitely an engineering black-eye.
  8. Mendel Leisk
    41,628
    Toyota USA parts website used to show similar (perhaps the same?) parts diagrams. Then they revised the site, ostensibly to improve it I would think, but the readily apparent reason would appear to be to hamstring the site. Not sure of the motive, but seems like they wanted to make it mostly useless, at least for searching, force potential shoppers back to dealerships. Or Amayama...
    You can use a hybrid approach, determine the part no on Amayama, then plug it in at Toyota USA's parts website, take advantage of the function that links local dealership parts departments, and see their "street prices".
    Being in Canada I've so far just purchased from Amayama, but if it was something massive, say an engine short block, it might be cheaper to go the hybrid route, and buy it just across the border. Depending on what it cost with customs. (looks like there's currently a 25% surtax :()
    #8 Mendel Leisk, Oct 1, 2025
    priumium likes this.
  9. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    Likely their developers are not competent enough to create sustainable links from an image overlay number to a url, it’s a super useful and impressive trick.
    It’s indeed a great way to filter for correct OE#, but if the actor also have the best price for an original Toyota part, why go elsewhere? It’s just profit margins added…
    Perhaps some can hope for TrumpImports.com, but I would avoid. :)
  10. ChapmanF
    18,300
    The old parts.toyota.com had all that, and it worked really well.
    Then they ditched it to bring out autoparts.toyota.com instead, where you can't search on diagrams, half the time can't even see a useful diagram, and you don't get the old site's useful detailed part descriptions with vehicle fitment crossreferences and additional markings and such, and instead you get like a two-paragraph AI-slop 'description' that repeats the part name a lot with stock phrases like preserving the great performance of your Toyota, all the better to manipulate search engines with, my dear.
    For a while, there were a bunch of dealers seeing it for what it was and sticking to the old system for their own parts sites, but it seems they've most or all been whipped into line now.
  11. priumium
    priumium Member
    312
    76
    Sweden
    2013 Prius Plug-in
    So, amayama ftw.
    I use it for many reasons (oe number searches) and I buy a lot from them in the hope they stay alive. Also they have a genius system for adding extra items after order and a super helpful staff.
