2003 with a P3125/302 DTC
Discussion in 'Generation 1 Prius Discussion' started by pigwot, Oct 1, 2025.
  1. pigwot
    pigwot Junior Member
    Our 2003 has 292,500+ miles on it and started having a stumble at the beginning of accelerating from a stop. Replaced plugs and coils as it was throwing a relevant code. Also cleaned throttle body and MAF. Ran fine for a few weeks and now went into limp mode.
    Silly me took it in to the dealer asking them to do a deep scan and provide me a readout of DTCs with INFs, and Live Data. They basically gave me what I already knew P3125/302 and said, “ not worth fixing”. Over the phone the service writer had started reading the Live Data related to the DTC, but when I picked it up they did not provide a full printout, despite charging me $205 for the ‘diagnosis’…
    The P3125/302, indicates a W phase inverter voltage sensor issue as far as I can make out. Does anyone have any suggestions as to how I could further diagnose this?
  2. VintagePrius
    VintagePrius Junior Member
    UK
    1998 Prius
    AIUI about the only thing you can check…unless you're comfortable inspecting the internal electronics of the inverter…are the connections between the converter/inverter and the HV ECU. If they check out ok then it seems replacement is the only other option. There's a couple on eBay…but they're in the UK where I am…so you might be best checking breakers wherever you are. Best of luck, Jay.
    mroberds and pigwot like this.
  3. mroberds
    mroberds Member
    143
    58
    2001 Prius
    For a 2001, the service manual suggests checking five wires between the inverter and the hybrid vehicle control ECU for continuity.
    Inverter HV ECU color
    I9-6 H11-26 black
    I10-1 H11-16 black
    I10-3 H11-7 white
    I10-4 H11-17 green
    I10-2 H11-25 red
    The last two (green and red) are associated with the W phase sensor, I think.
    At the inverter, I9 is a six-pin connector and I10 is an eight-pin connector. At the ECU, H11 is a 28-pin black connector.
    If all that checks out, it's "replace converter and inverter assembly".
    Again, this is for a 2001. I've heard that 2001, 2002, and 2003 are all the same, and then I've heard that 2001 and 2002 are the same, and 2003 is different.
    Your mileage may vary. :)
