Reasonable or Money Grab? Dealer's Recommended Maintenance List
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by c.ortiz108, Oct 1, 2025 at 8:08 PM.
  1. c.ortiz108
    c.ortiz108 Member
    110
    26
    San Francisco, CA
    Here's a list of things Toyota said were need for a 2016 Prius at 123k miles last October. They owner declined, believing the service center was just trying to make money off him. He has since driven the car another 33k miles. This a car I'm considering buying, but this is giving me pause. It seems like an awful lot to ignore, especially given that the seller admits he doesn't know much about cars:
    REPLACE INVERTER COOLANT
    REPLACE BRAKE FLUID
    ALIGNMENT - FRONT END
    CATALYST WITH GASKETS
    PERFORM FUEL INDUCTION CLEANING SERVICE
    ENGINE COOLANT FLUID EXCHANGE SERVICE
    TUNE-UP - MINOR
    MASS AIR FLOW SENSOR CLEANING SERVICE.
    PERFORM THROTTLE BODY SERVICE
    FUEL INJECTION CLEANING SERVICE
    TRANSMISSION SERVICE DRAIN AND FILL TRANSMISSION FLUID
    ADS AND ROTORS (REAR) - REPLACE (BOTH)
    51,552
    it's a mix, some good, some bad. i just follow the maintenance schedule and advice here, rather than fall for dealer yacht payment nonsense
    PrimeDan and c.ortiz108 like this.
  3. a2058
    a2058 Junior Member
    Westchester, NY
    2019 Prius
    XLE AWD-e
    Catalyst with gaskets point to heat exchanger leak… either suspected or detected…
    c.ortiz108 likes this.
  4. c.ortiz108
    c.ortiz108 Member
    110
    26
    San Francisco, CA
    I was afraid of that, actually. I know that can be a really costly issue. Considering that the driver put another 33k miles of driving on the car after that was flagged, it's even more concerning.
  5. a2058
    a2058 Junior Member
    Westchester, NY
    2019 Prius
    XLE AWD-e
    If the leak there was small yet and if the driver kept an eye on it and if he topped it up like daily, it might be still ok. I did that for about 6 months before doing the bottom side bypass. But of course that’s big IFs….
  6. BiomedO1
    3,160
    1,673
    SacTown, Ca
    We're just speculating on the EGHE unit. If this is a CARB state car, that unit should still be under warranty - so those gaskets should also go with the warranty.........
    IMHO; both coolants needs to be replaced, brake fluid needs flushing out, ATF and spark plugs needs replacement and get a second opinion on the rear brakes. It has more than a 100K on the clock. That's the minimum that needs to be done. The TPMS sensors are also near EOL too; if they've never been changed.
    Hope this helps.....
  7. c.ortiz108
    c.ortiz108 Member
    110
    26
    San Francisco, CA
    Yeah, he didn’t…. He said a few times he knows nothing about cars but that it’s okay because it drives fine.
  8. c.ortiz108
    c.ortiz108 Member
    110
    26
    San Francisco, CA
    It does, thanks. That seems like quite a lot of maintenance to have deferred for 33k miles, even aside from the potential gasket issue.
  9. BiomedO1
    3,160
    1,673
    SacTown, Ca
    You don't know if the guy is lying to you and/or pretending. It drives fine????? How does he know??? Sounds more like he's deflecting and setting up an excuse; if you find something major wrong with the car after purchase....
    Just my 2-cents
