Front bumper license block cover plate
Discussion in 'Gen 5 Prius Accessories and Modifications' started by FenwickFish, Jun 24, 2024.
  1. FenwickFish
    FenwickFish Junior Member
    TN
    2023 Prius
    Limited AWD-e
    Hey everyone,
    Just recently got my 23 limited and like everyone has said a hundred times over, I hated that lego block on the front bumper.
    So I thought I'd share with you something I had made to try and make it look less ugly.
    I found a site that deals in license plate delete plates and worked with them to come up something to cover the entirety of the block.
    I also thought getting one that said TRD would be a little tacky and I really like the way the PRIUS on the back of the car looks, so I figured out what font was used and had this put together. It's made of pvc and is just attached with 3M tape, so it was able to conform to the slight concave of the block.
    Just thought you all would like to see. Personally, I really like it!
  2. Blackat
    Blackat Active Member
    476
    337
    Colorado
    2023 Prius
    Limited AWD-e
    Here in CO we are required by law to have a front plate so.......
  3. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    I like it and am surprised that Toyota didn't think of it. You just need to change it to "#Prius' so it matches the rest of the tags around the car.
    pramodhrachuri, tat2boy and Templeton like this.
  4. FenwickFish
    TN
    2023 Prius
    Limited AWD-e
    I had thought about it. But really like the way it looks on the back of the car, so I wanted it to kind of match/ give the same vibe on the front.
    If I added a # it would also mean I'd have had to have the font closer together (which IMO would have looked kind of off given how spaced the letters on the back are) and slightly smaller which would have made it less doable because of the support lines needed.
  5. Cactus
    Cactus Junior Member
    32
    Mountville PA
    Did you consider having the lego block removed?
  6. Trollbait
    12,653
    Same in Japan. Thus why the bump is there to begin with.
  7. Mr.Vanvandenburg
    1,357
    578
    2020 Prius Prime
    People have been putting front plates on with their own message or idea for years in no front plate states. I guess this is a stylish version. But a factory plate frame could be easily installed. I wonder what prevented Toyota from making a smooth bumper and adding the plate frame as an accessory like they used to.
  8. Michelle hillis
    Michelle hillis New Member
    2024 Prius
    I really like dislike th3 bump and really like your design. Any more info on the source to have it made. Much appreciated
  9. Matthew Jacob
    Matthew Jacob New Member
    Winter Garden, FL
    2024 Prius Prime
    XSE Premium
    I would like to purchase one of these, are you able to share where you got it? Thank you
  10. Pripri Prime
    Pripri Prime New Member
    Montreal, Canada
    2024 Prius Prime
    XSE
    Hi there,
    I would be interested to know as well :)
  11. RollingPanda
    RollingPanda New Member
    24
    Fort Worth Texas
    2025 Prius
    Limited AWD-e
    I am interested also!
  12. AddMoreGas
    AddMoreGas Junior Member
    87
    52
    57
    Dallas
    2024 Prius Prime
    XSE
    I am sure you are "required by law" to only go the speed limit. Do you do that?
  13. MScelery
    MScelery Junior Member
    83
    24
    Mississippi
    ummm did anyone ever figure out how to get one of these? I’d buy it. Quickly. But preferably in a gloss black.
  14. FenwickFish
    TN
    2023 Prius
    Limited AWD-e
    My bad everyone! I forgot to actually check back on this.
    So I went through visualautowerks to have this made.
    I gave him the dimensions and as well as a simple design I came up with and he took care of the rest for me.
    The font they used for it was actually a free font file that I was able to find online (classiccobraexpand).
    I'm sure if you guys send him an email he should still have all the information for it. But I can also dig into my emails and find everything if that would help.
  15. MScelery
    83
    24
    Mississippi
    Yeah man! If you could send even like your order number so I could reference it, that would be awesome!
    Julio_E and RollingPanda like this.
  16. RyanGphoto
    RyanGphoto New Member
    Tampa, FL
    2025 Prius
    I too would love to have the info and would really appreciate it.
    Thanks
    Ryan G
