Adding coolant to a (potentially) very low 2nd gen
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Th0mathy, Oct 2, 2025 at 11:15 PM.
Tags:
  1. Th0mathy
    Th0mathy New Member
    Yesterday
    Michigan, USA
    I have a 2008 Prius with 215k miles. I was never aware there were two coolant reservoir, and while the hybrid coolant is full, there's no coolant to be found in the engine's reservoir. I want to add coolant, but I'm unaware of the best way to do it.
    1. Should I just fill the engine reservoir, wait and see if it goes low again, then add more? Or is it possible for me to add fluid directly to the radiator?
    2. (Ignore question if I can't add directly to radiator) If I can add directly to the radiator, how much should I add? Should I add coolant until it nearly overflows? Or is there a better way to tell if the radiator is nearly full?
    I'm just looking for tips on solving my low coolant situation here, thank you
  2. Hayslayer
    Hayslayer Member
    331
    181
    If you're not having any engine temperature problems, just add coolant to the reservoir and let the system take care of itself. The fluid from the reservoir will get siphoned into the radiator as the engine heats and cools. Monitor the level for several days and add if it lowers. Level can be hard to see on a Gen 2, so use a flashlight at the side of the reservoir to help see coolant level in the tank.
    Look at the lower passenger side of the engine, where the water pump is. When losing coolant, it's one of the more common reasons. Look at the inside surface of the water pump pulley for any evidence of pink residue. If there is some, and it's dry then you have a very slow seep from the water pump seal, but is not a crisis. If it's wet, you need to replace the pump soon as possible because the seal is failing.
    Th0mathy likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,016
    788
    South Central PA, USA
    You should fill the radiator to the very top and then fill the overflow bottle to the full line. Drive the car for a day or two and recheck the level.
    Th0mathy and BiomedO1 like this.
  4. BiomedO1
    3,162
    1,675
    SacTown, Ca
    1. Make sure everything is cool to the touch.
    2. If there's a radiator cap on the radiator, check that first. If it isn't full (all the way to the top) fill it. ONLY use compatible Toyota coolant, incompatible coolant may jell and cause other issues. If there isn't enough coolant in the radiator, there's NO "siphoning action" to draw the coolant from the coolant bottle.
    3. Fill the coolant bottle to the FULL line.
    4. Monitor it for the next week or so.
    Hope this helps.....
    PS, you should probably read the operations manual for that car; so you know how to do simple things like this......
    Th0mathy and Brian1954 like this.
  5. Tombukt2
    12,695
    2,268
    It takes an hour it's like watching the grass grow you want to uncap the rad. And fill thru neck slooooowly. When you can get water to stand at the very top of the filler neck for 5 minutes then it's full . 5 min is a loooong time. After you cap it off make sure the reservoir is full to bottom of its neck . Now you should be good drive car . Tomorrow when you walk out in the morning crack the cap let vacuum subside and water should be in same place on neck if not add till it holds full . If this continues you have a small drip somewhere you need find.
