Environmental News
Discussion in 'Environmental Discussion' started by tochatihu, Oct 22, 2015.
  1. tochatihu
    tochatihu Senior Member
    9,850
    3,806
    Kunming Yunnan China
    2001 Prius
  2. ChapmanF
    18,463
  3. bisco
    52,294
  4. bisco
    52,294
    might be more important to clean up the debris on earth first
  5. tochatihu
    9,850
    3,806
    2001 Prius
    Chap's link is correct. Debris on earth is also a concern but it moves much slower.
  6. bisco
    52,294
    it's doing a pretty good job on the oceans and water supplies
  7. bwilson4web
    16,332
    Dang, I was pumped for EV charging discussion since I think I’ve figured out a clever solution. Maybe later.
    As for orbital debris, in theory it can become a barrier to our planet future satellites. The Starlinks are at a low enough orbit they require an active boost system or they naturally decay to reentry and burn-up.
  8. T1 Terry
    T1 Terry Active Member
    929
    491
    Was this part of an Elon strategy to litter the area so badly that no competitor could use the same region and be forced into achieving a higher orbit?
    The fact he has made it so messed up that his own satellites have to play dodgems, might mean he didn't realise how fast it could escalate into a virtual no go zone ..... his satellites can dodge the bits at the moment .... until they run out of fuel, but what about all the other junk that is unpowered and can't play dodgems, so collide and just add more litter ....
    The smaller the pieces, the harder to detect, but they still make holes in other objects travelling slower than they are and at a different orbital path .....
    Maybe, they have built a space protection layer that will stop the Martian's from invading :LOL:
    T1 Terry
  9. bwilson4web
    16,332
    The relatively higher drag at Starlink altitudes quickly degrades any unpowered ones into re-entry. Higher orbits have less residual drag so they have a longer interval to play ‘bumper cars.’
  10. tochatihu
    9,850
    3,806
    2001 Prius
    Star-de-linked are now re entering about one per week. One assumes they use their last bit of ion thrust to splash at Point Nemo but I have not seen that discussed.
    An important risk of orbiting pieces too small to track is disabling orderly de-orbiting of satellites. Those then become bumper cars with large cross sectional areas. Bumper cars might not be an ideal analogy because that game is based on surviving impacts.
    Giving Earth an orbital shield of Kessler debris might work in sci fi, but if ETs manage to get all the way here, they'd need to have good bumpers already installed.
  11. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I am a senior life member of the IEEE, so if you can't get to an article, I may be able to access it, save it to my web site and provide access.
    JeffD
    ps. @bisco, I can play a scientist on TV so ask questions.
    bwilson4web and bisco like this.
  12. ColoradoBoo
    ColoradoBoo Senior Member
    1,264
    870
    Monument, Colorado USA
    US Space Force doesn't have any problems tracking space debris. I've seen their displays and zoomed in and they can even see bolts floating around. You click on the object and it will ID it for you. (Example: Cat ##, Jun 74, Skylab bolt)
    More recently, they are using satellites to catalog and track debris.
    If space stuff fascinates you, do some internet searching about "Starfish Prime" You're welcome....
  13. hill
    8,898
    Funny that this explosion would come up. My father-in-law (now in his mid 90s) was out on that Atoll observing his electrical engineering handiwork.
    Probably not many left that actually worked on those early experiments. Although apparently a treaty that prohibited experimenting to improve emp's - yea it still went on. That blast took out power on the island of Kauai.
    good times
    #2853 hill, Oct 3, 2025
    ColoradoBoo likes this.
  14. tochatihu
    9,850
    3,806
    2001 Prius
    "US Space Force doesn't have any problems tracking space debris" Larger than 1 cm, no one (in that business) does.
    "More recently, they are using satellites to catalog and track debris." Satellite capable of doing this by plasma wake detection from smaller bits has been described and designed but not launched yet.
    In a timely story, Stephen Clark lists largest orbital debris hazards:
    Removing these 50 objects from orbit would cut danger from space junk in half - Ars Technica
    I am not aware of any plans to de orbit large chunks. That would be helpful.
    "If space stuff fascinates you ..." It does, and others here besides me also. I would presume all such know of Starfish Prime.
  15. tochatihu
    9,850
    3,806
    2001 Prius
    Mt. Everest climbing information, as a news link follows below.
    Recent years successful ascents about 850. Recent years success rate about 60%. Average cost about USD$50,000 (with large variation). Main climbing season April through May.
    Just now there are about 1000 climbers stranded on the mountain. That is similar to an entire year's number and it is October. Seems there was an unseasonal weather opening and they 'went for it' and the opening closed.
    Nearly 1,000 hikers trapped on Mount Everest as heavy snow halts access
    Best scenario I suppose would be that most have not yet summited, so they would have more supplies and not been battered by the final leg. Waiting and walking out as opposed to helicopter evacuation of so many.
    I don't know that an October mass ascent has been attempted before.
  16. Merkey
    Merkey Active Member
    318
    291
    Birmingham, Michigan
    Amazing that Edmund Hillary climbed it in 1953 w/o all the high tech stuff of today.
  17. tochatihu
    9,850
    3,806
    2001 Prius
    1953 ascent without mentioning Tenzing Norgay gets a yellow card.
    Current high tech is more than equipment:
    Mount Everest Climbers: Total Summit Count and Yearly Stats
    Link does not mention drugs mainly Erythropoietin (EPO) and see others here:
    AAC Publications - Mountain Medicine, Performance-Enhancing Drugs and Climbing
    Nor mention pre-climb training that now includes sleeping in low-oxygen tents.
    Reinhold Messner and Peter Habeler achieved the summit without bottled oxygen in 1978. This should rank with 1953, and Messner was unique:
    Reinhold Messner | Academy of Achievement
    Meanwhile, many are right now on Everest slope not facing certain survival. If this goes badly, mass appeal of 'the 8000s' will be revised.
    Merkey likes this.
  18. tochatihu
    9,850
    3,806
    2001 Prius
    BBC America coverage suggests this was an unwise group of holiday goers in Tibet, and that evacuation is proceeding successfully. This puts a different face on it.
    It is the mid-autumn festival in China now, but most (of us) only have large family meals and exit with large boxes of moon cakes we don't really like, but cannot refuse.
  19. Merkey
    318
    291
    BTW, what does a yellow card indicate?
  20. bisco
    52,294
    a lot of it is luck regarding weather. i just cannot put myself in their hiking boots
